Page 1 of 7 12345 ... LastLast
Results 1 to 25 of 165
    Very Active Member zuni's Avatar
    Mar 2014
    JAX FL
    Default Front Sprocket Failure
    Trust you gut folks, sometimes you get a feeling that something is not quite right. Take a second to check it out. Jumping around on either RT or F3s or F3t left me questioning if I could feel something or it was imagination. Yesterday the splines on the front sprocket had finally worn enough that it spun on the shaft. Less than 9,000 miles. Not happy but the timing could have been worse, much worse. Had I been trying to pass on a two lane road or make a left turn across traffic when it failed I would have been left hanging. It is something worth keeping an eye on. Take a small flashlight and peek behind the cover that is in front of the rear sprocket. There is a small pan underneath that filing will collect on. Additionally since the shavings have become "charged" they stick to other metal parts and will even stand up in the tray. A one minute check could give you an idea if you have a problem or need a closer examination. The failure also explained why my belt kept creeping and needing adjustment.
    Now the waiting game. No dealer appointments until a week from tomorrow and they won't order parts until they see it and verify with BRP that it is warranty. Wonder if this is a part or build issue. This was the first F3s delivered in FL. I only have 9k on it and I know others have more. Curious.
    Thanks for the warning...
    I'm glad to hear that it didn't let go at an "inopportune time"...
    Apr 2011
    GREENVILLE, SC
    Default YUP, YUP & YUP
    HAPPENED TO ME WHEN I TURNED INTO THE PARKING LOT OF MY CREDIT UNION......
    happened to 2 others that i know.... all 3 of us had it fail around 17,000 miles.... yours was an early-bird....
    after the R&R was performed, i looked at my old one, and it looked like 'pot' metal; aka, junk.... i'm a retired engineer, and i'm here to tell you that 'low bidder' parts are 'low quality' parts.... there are just some things that shouldn't be purchased from those people...
    best of luck, and ride safely....
    SPYD3R
    Dec 2014
    NY
    Looks like a good aftermarket part in the making.. I would buy if not too overpriced! What about it Lamonster?
    Sent from my XT1585 using Tapatalk
    Apr 2012
    Northglenn Colorado
    Quote Originally Posted by zuni View Post
    great pics but I have no idea what I am looking at.
    Mar 2014
    JAX FL
    Quote Originally Posted by Tazzel View Post
    Left side of the bike below the front sprocket. My collection of metal shavings that should have made up the splines of the sprocket.
    CJ JAX
    Jul 2010
    Las Vegas, NV
    Default Buttercup had that, too!
    A mild jerk in the drive chain. The good news is the front pulley is softer than the output shaft, so it goes first. It is much easier to change!
    Joe Meyer
    Mar 2011
    oregon
    This was a common faliure in the 08 era turns out a lot of the problem was way to high of belt tension BRP lessened the specs and I mostly fixed the problem
    Houston
    The failure is the bolt coming loose. Its not the pulley that is the problem. Once the bolt is loose, either the pulley or the shaft is going to fail, the pulley is the easy to replace part so designed to fail first.
    Check the bolt torque on that pulley every oil change.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Mar 2014
    JAX FL
    Bolt is tight. Sprocket part number is superseded by new number. Guessing they made a change.
    CJ JAX
    Invalid Emails
    Sep 2015
    Cheshire Ma
    Yamaha Warrior from 02 - 05 had this problem it turned out that the pulley lock nut was the problem it was fix in 06, but it usually took the shaft with it. Knowing this I check mine for filings or dust whenever I think of it, also when I got it my belt was at 240, I dropped it to 200, after reading all the posts about what it should be I went to 180, didn't think I wanted that much tension on the drive pulley, also my vib went from 55-60 to just a little bit around 70. So if a few have had this problem it would probably be a good idea to check it every so often, if you reach up behind the cover you can feel the pulley if your fingers come out with black dust better check further.
    Mar 2016
    Indiana
    I had it happen on my 08. I keep an eye on the bolt and check it for tightness every 1000 miles. It will come loose. Someplace there is a bulletin from BRP to look out for that.
    Apr 2012
    Northglenn Colorado
    which bolt are we talking about?
    Aug 2015
    Northern California-Sierra Mountains
    Default Pulley
    Agree, need more help with locating the bolt. An expanded view of the bike with close ups there after. Much appreciated.
    Mar 2014
    JAX FL
    Quote Originally Posted by Steamer View Post
    In my case the bolt was tight so that wasn't what caused the issue. If you remove the cover (3 socket head cap screws from the front and a push pin type at the top on the back side of the frame pipe) you can access the the front sprocket to check the torque. In the picture the cover is in between the two frame caps. The exploded parts diagram shows the bolt through the smaller front sprocket.
    CJ JAX
    Dec 2014
    NY
    What is the correct torque?
    Jun 2010
    Las Vegas
    A Las Vegas 15 F3 just had this happen to him. Took the dealer forever to figure out the issue.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jan 2016
    PA
    I have been doing a search for part numbers and I can find no superseding part num for the original:
    POULIE 28 DENTS*SPROCKET 28 TH
    705502134
    Are my sources out of date?
    705502134
    Jul 2013
    Brights Grove, Ontario, Canada
    would this not be a warranty issue?
    2017 F3-S , circuit yellow
    May 2012
    sussex, nj and tug hill, ny (west turin)
    Quote Originally Posted by Doug View Post
    I was one of the three that had this issue. it happened at about 12k for me. it is definitely a warranty issue. there was a little scuffing on the shaft but not enough to worry about. the bolt loosening up was definitely the issue that caused the spinning of the sprocket. again, i'd suggest checking it at every oil change, or even more frequently. definitely a warranty issue though!!!
    Mar 2014
    JAX FL
    Quote Originally Posted by spyderCodes View Post
    705502134
    705502134
    I guess. I had to order the part since the dealer wouldn't until they verified the issue and they got BRP to agree it was warranty. agreed to reimburse me for the cost if it was bad and covered. The parts department confirmed the change in part number.
    CJ JAX
    Mar 2015
    US
    hey, did you by chance have the belt readjustment to address the vibration?
    mark
    Mar 2014
    JAX FL
    Quote Originally Posted by Nyparrothead View Post
    mark
    The belt was adjusted twice because it wouldn't track straight. It would move to the inside of the rear sprocket after about 1k miles. Obvious now that the front sprocket was going and as the play in the sprocket increased the belt would move. I don't think that belt tension is what caused the problem with the sprocket but I do think it is a factor in when it happens. I the highest mileage I know of personally was around 26K on a 2016. Others sweem to fall in the 12k to 17k range and mine at 9k. What I don't know is if more tension makes it last longer or kills it sooner. You could make an argument for either way. A looser belt would have more flutter which could shake the pulley more causing an early failure or a tighter belt would apply more loading to the splines and shifting (loading and unloading) could cause an earlier failure. In either case my sprocket is toast I a sit (not so patiently) waiting for an appointment at the dealer so they can examine, talk to BRP to see if it is warranty, then order parts. If I was in a cooler climate and had a limited ryding period I would probably be screaming a bit but thankfully here in FL we get to ryde year round. To short circuit the process some I ordered the sprocket and it should arrive just i time for my appointment next Friday.
    CJ JAX
    SpyderLovers Sponsor capt.jim's Avatar
    Mar 2008
    homestead, FL>
    The F3 and RT both use the same part# for the front sprocket. The RT's are using a substantially higher belt tension, are they having the same failure rates with the splines wallowing out?
    Mar 2014
    JAX FL
    Quote Originally Posted by capt.jim View Post
    Haven't heard about RT problems. The F3 now has a new part number for the front sprocket. Guessing some kind of change? Tighter material spec? Of bigger curiosity is how belt tension played into the equation. As I stated above I could see it either way. In any case I see belt tensioners in our future for both bikes.
    CJ JAX
