Amplifier
How do I install an amplifier to my stock 2014 limited stereo
Sent from my SM-N910V using Tapatalk
AMP
I'm curious .....why do you want to do this ???.............Mike
Upgraded the speakers and just thought it would help at high speed
SPEAKERS
What speakers did you put in ????
Alpine 5 1/2" front, 4"in rear
ALPINE SPEAKERS
They are quality speakers and work very well in vehicles. However on a Spyder they may need more power................... Send " Bluestratos " a PM, I know He added a separate AMP on His RT and can give you accurate info on how to proceed......Good Luck .................Mike
Thanks for your help
Upgrade amp on Rt
Did you end up upgrading the amp on your Rt? I find mine underpowered at higher speeds and was looking at options.
Thanks for any and all assistance
UPGRADED AMP
I think if you keep the OEM speakers ..... a better or bigger and better AMP won't do you any good ..... It will exceed the limits of the Speakers ....... the OEM amp already does that ...... I switched to 2 ohm JBL speakers F & R and have the OEM amp and my system now ROCKS ....... Mike
I put Bluetooth speaker/microphone set in my helmet from Sena and that is good enough for my old ears.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
