Results 1 to 8 of 8
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    Default newtons to lbs belt tension
    when laser alignment was done , my belt and rear tire alignment
    was set. i had the 70 up vibration like most. dealer set the belt at
    what they told me was 1100 newtons. using the conversion thats
    about 250 # tension . i havent gotten a kricket yet, but that sounds
    mucho tight but its within spyder specs. the vibration now moved down
    to the low 50's up to 60 on acceleration in 6th gear only. took it back and
    they told me you cant have it both ways. think i would rather have it at
    70 plus. what are most of you running ?
    when i had my victory, you had to wait till the belt was dead cold
    because it tightens as it warms as it has kevlar belts . how does this
    compare to a brp belt? anyone know much about these ? irv
    ps- the vibration now is livable. just worries me. you can feel it.
    2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
    and some little stuff. setback utopia backrest, baja ron
    sway bar, oem adj. air deflectors, marlin gps compass,
    lamonster fbb foot pegs[modified brackets], lamonts
    vibration damper, rock guard, and side case stiffener kit,
    . brp comfort seat. , fomozas and
    altimax, magic mirror mts, and wide mirrors.
    [joyce & irvin toms]
    Default NO VIBES
    I use the KritKit to set lbs........and I only measure it " TIRE ON THE GROUND " ( it's much easier & just as valid ).... I have my 2014 RT at 185 lbs., and as stated above I have NO VIBES ....Mike
    Very Active Member retread's Avatar
    May 2008
    Bargersville, IN
    A newton is a measurement of force, your belt is adjusted to a tension. Something like the force necessary to accelerate 1 KG at a rate of 1000 meters per second squared, if I remember right.
    john
    Default Let's see....
    If you were having the vibrations at 70mph and once adjusted the vibrations are now at 50/60 mph it would seem they are going the wrong way. As Mike stated running it lower would be better. I run at about 180/185 and have no problems. I do have a tensioner as well....
    ​2012 RS sm5
    When I had my bike in for servicing: the dealer tightened the belt up.
    The Harmonic vibration that I had been feeling has disappeared, but my fuel mileage has dropped by approximately 15%
    Has anyone else noticed this?
    Default TIGHTER =
    Tighter = more FRICTION + more WEAR on all components in-volved .......But don't take my word on this wait un-til someone you trust says it like BAJARON ..........or Sledmaster .............Mike
    May 2016
    mt morris il
    talked to ron and also the owner of smooth spyder.im told the 14 and up rt's run more tension than the early ones.
    Active Member fjray's Avatar
    Aug 2015
    central oregon
    I run the 2015 RT at 160 with the wheel elevated which seems close to 180 on the ground. I then adjust the smooth spyder to mid range with the passenger on board. Still get some vibration on ocassion but very little.
