Results 1 to 25 of 50
Thread: F3 Rear Tires
    Jun 2015
    Seattle area
    Default F3 Rear Tires
    What rear tire options are available for the F3?
    Jun 2010
    Las Vegas
    The rear tire on all Spyder models and years is the same size so you have the same options as all other Spyders.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Default TIRE OPTIONS
    Quote Originally Posted by RedStar View Post
    Unless the rear fender is very close to the OEM tire the General Altimax RT 43 in 215/60-15 would be an excellent alternative ......Mike
    Bay of Plenty New Zealand
    The correct F3 rear tire size is a 225/50 r15 either use a Toyo or Kumho for good grip and wear, do not go back to the Kenda its grap
    Houston
    I've been pretty happy with the increased traction and high quality provided by the Yokohama S-Drive I have on my F3S. I have installed a good number of these for customers. They generally balance with less than 1 oz. Have had several that needed zero weights. Great high performance tire option for the spyders.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Active Member _..stiffler..'s Avatar
    Feb 2015
    NB Canada
    This will be my next tire
    Sent on Note 5 in Taptalk
    2011 RT Limited , White
    Dec 2014
    NY
    Which size exactly? Thx.
    Houston
    Quote Originally Posted by johnny pop View Post
    205/55 ZR15
    Houston
    Quote Originally Posted by _..stiffler.. View Post
    Looks like a great option. Unfortunately its not available in the US.
    Jun 2010
    Las Vegas
    I had purchased one when they were still available here but didn't get it installed before my 13 burned. I wound up selling it to a friend since I wasn't sure if the 14 was going to have the same tire size. She still has it on her Spyder and says it handles great and has worn well. I wish they sold them here still.
    2010 RT- 622
    Active Member monkeyboymorton's Avatar
    Sep 2015
    UK
    Edit - it was a 16" I found - bloody google!!
    Can't find them in the UK, the T1-R is more common here and could well be my next rear tire.
    | 2015 F3-S | Heated Grips | USB Ports | RAM X-Grip | RT Sway Bar | '2 Up' Rear Shock | SHAD Bag Kit | Oxford Aqua 50 Dry Bag | BRP Rider Backrest |
    Feb 2015
    NB Canada
    Ahh. Crappy
    Jun 2015
    Seattle area
    I like the experience you have wrote about. It speaks volumes about what to expect. The idea of little or no weights is a real plus. Could you tell me a good source to acquire this tire please? My original tire is junk, wear bars were showing in the middle of the tire after 4,000 miles. The fronts are ok, but I might change them out too. What suggestions do you have for them?
    Feb 2015
    NB Canada
    I cant find the s drive in 225/50/15. Just 205/50/15 or 205/55/15.
    Any ideas?
    Active Member JIM W's Avatar
    Mar 2016
    Howard's Grove WI.
    I was strongly considering Yokohama s drive but was told by the Can-Am dealer the beads are different on the car tires and don't fit correctly.
    Do you think they're just feeding me a line of
    Sep 2015
    UK
    Any ideas?
    205/55 ZR15
    Answer is as above from JC. To cut a lot of threads short, the Yoko S-Drive 205/55/15 works out almost exactly the same size as the OEM Kenda 225/50/15 when fitted.
    Houston
    We purchase through an arrangement with Discount Tire. They supply the tire and mount on bare rim. We do the balance and install on the bike. Discount is not equipped to R&R the rear rim on a Spyder.
    Sep 2015
    UK
    Quote Originally Posted by JIM W View Post
    Short answer - yes. Again, to summarise lots of threads on here over the years, the spyder wheels have exactly the same bead as car wheels. They are not M/C wheels.
    The OEM Kenda tyre are 'badged' as M/C tyres but are in fact car tyres in how they fit the rim. Construction of the tread I don't know about, but if I was to guess would say they are are a car tire effectively.
    The upshot of all this is you can fit car tyres if you want, but your dealer may refuse to fit them for you. Hence all the tutorials/videos on how to remove the back wheel yourself.
    I for one will be doing my own rear tire change when the time comes and fitting either the S-Drive or a Toyo. I really like JCs idea of an R888 if we can get a size to fit. R888s run big in my experience from the Mitsubishi EVO tuning scene.
    The bead profiles on Can-Am rims ARE MADE for car tire beads!!
    Car tires will & do fit perfectly, because the Can-Am rims & car tire beads were made for each other, but any other tire with a motorcycle bead WILL NOT FIT SAFELY!!
    So when it comes to dishing the BS, any dealer who's telling you that car tires won't fit because their beads aren't correct is right up there with the best BS artist, &/or either lying knowingly thru their teeth or so ignorant you really shouldn't even let them look at your Spyder!!
    Active Member deer30084's Avatar
    Tallahassee, FL
    Way too soon for me to post here, but when the tyme comes, Y wyll have my dealer Ynstall whatever he has in stock. I ayn't set up to do my own tyre work.
    John F.
    Tallahassee, FL
    2015 Spyder F3 SE6, black
    BRP Driver/passenger Footboards
    BRP Adjustable Passenger Backrest
    Blue Ridge Windshield
    MRA X-Creen Tour, clear, clamp-on
    H4 LED Headlights
    F3 LED Fog Light Kit, LED Amber Halo Ring Kit, LED Tail Lights, F3 Rear run/brake/turn LEDs
    Easy Brackets
    Leatherworks, Inc. 120 Special Slight Angle Saddlebags
    Custom Dynamics Front Mud Flap LED lights, Street Magic Front Fender Tips, Double Feature Lens
    2-up rear shock
    Idler pulley kit
    Feb 2015
    NB Canada
    Quote Originally Posted by monkeyboymorton View Post
    In height yes. But almost an inch narrower. May not be much but when looking at it. Looks like alot. 205 IMO would look funny and perform a bit different.
    Anyone have any pics of them side by side on the vehicle.
    Stiff
    Houston
    Stiff
    No in width they are nearly the same too. The NOMINAL size numbers are different. The ACTUAL dimensions are only 1/8 inch narrower tread width on the Yoko and contact patch is actually wider.
    Jun 2015
    Seattle area
    Just ordered the Yoko S-Drive!
    Sep 2008
    TX
    The first number is the tire width in millimeters. The difference between the tires is 20 mm or just over 3/4 inch. The second number is the sidewall height as a percentage of the width, that is the first number. The overall height of the tire is the last number in inches, the bead diameter, plus two times the second number. In doing the calculations you have to remember to convert the dimensions into common units.
    225 - 205 = 20 mm = 0.787" nominal difference in width
    (Width × height ratio × 2 / 25.4) + bead diameter = nominal tire height in inches
    (205 × 55% × 2 / 25.4) + 15 = 23.88
    (225 × 50% × 2 / 25.4) + 15 = 23.86
    Although they are close to the same height, somewhere the nominal tread width is different by over 3/4 inch.
    Wayne
    pauly1 - SpyderDeb's 'wrench'
    IBA #48220 SS1000 BB1500
    ^^ That's all fine when you are talking nominal tire sizes, but some tire manufacturers base their tire labelling on the bare tire carcass, then they overlay the tread & sidewall protective layers onto that carcass, resulting in a measurably 'larger' tire; while others base their tire labelling on the nearest nominal size once all that extra rubber has been added!!
    So to compare exact tire dimensions, you really need to check the physical measurements/specs of the particular tires themselves - one brand of tire that might be labelled 215/55x15 because that's what the naked carcass measured can actually be very close in size or possibly even slightly larger than another brand of tire labelled 225/50x15 simply because that second manufacturer based their labelling on the fully wrapped & finished tire!!
    You'd think that using a standard labelling system would mean that different tires labelled with the same nominal size would be close in size, but until there are mandated & enforced measuring conventions in place, some manufacturers will try to use the potential differences between what it's measured in this instance/by this method vs what labelled size will work to their advantage! Sorry, but that's just how the Mercedes' bends!
