Results 1 to 11 of 11
    Jul 2016
    Default LED bulbs for 2014 ST
    Hello: Wondering if someone could give me information on obtaining LED headlight and fog light bulbs for a 2014 Spyder ST. Kinda confusing trying to find the correct ones. Maybe the correct numbers, along with the best place to purchase. Thanks a bunch!
    Springfield, MO
    This is what we have that works for the headlights.
    http://www.lamonstergarage.com/h4-le...-spyder-f3-st/
    I'm checking on the ST foglights now.
    Greenville Tx
    Quote Originally Posted by Lamonster View Post
    I got your Headlights, They are really great! I also have the add on BRP fog lights. The fog lights are a yellow light but they still fill in nicely the light right in front of the spider. If I turn them off the LED lights do not give much light on the close in area right in front (Maybe 30 or 40'). It will be interesting to see the difference by putting in LED fog lights.
    2017 F3 Limited
    Member SpyDnAZ's Avatar
    Jun 2015
    Tucson
    Default YESSS!!!!
    I have the Lamonster LED headlights and love them. Recently picked up some BRP foglights but hoping for the LED Foglights.
    Active Member garageguy's Avatar
    Jan 2015
    Flint Hill VA
    Default LED headlights for ST
    Yes!! finally there is an LED alternative for the ST! Looked at the F3 install video on lamonster's site, but what are the tips for an ST DIY install?
    Jun 2010
    Las Vegas
    Quote Originally Posted by garageguy View Post
    Find someone with really tiny hands. During the NorCal Rally an ST owner had a headlight bulb out and we said we would replace it for him. After doing that I can understand why BRP discontinued the ST. There is a wire that has a plug on it that you have to hook up on the bulb. Well in trying to get it plugged in I dropped it, and somehow this 6" long wire with a 1" square plug on the end of it managed to fall deep into the dark abyss of the ST. We had to take all of the right side tupperware off to find it. So my bit of advice is don't drop the wire. Good luck.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jan 2015
    Flint Hill VA
    sigh >> and I have large hands. maybe I'll stick with the stock halogens.
    I try to do all my farkeling myself to avoid dealer pricing and ineptness
    Aug 2013
    SF Bay Area
    I did mine and what made it easier was I was also working on servicing the engine so I had all the plastic off.
    Here are pictures of what the inside of the dash looks like.
    Behind speedo/tach:
    With Xenondepot LED bulb installed.
    2021 F3 Ltd , Magna Red
    Active Member JonYiong's Avatar
    Singapore
    Hi, can you please advice which size LED should I get HB3 or H4 for ST Limited Low beam?
    Btw, mine has hyper flesh issues. After trying press and hold on the hazard light switch 30sec method don't work.
    Any advice?
    Aug 2013
    SF Bay Area
    The bulbs have changed since I got mine. If you go to the XenonDepot web site you can select the vehicle and it will tell you what to use. (HID is technically illegal unless the OEM was HID or Xenon)
    Aug 2013
    SF Bay Area
    I have a problem with 4 way flasher. I installed CustomDynamics rear flashed and my turn signals work fine. It the 4way makes the left side barely flash. Haven't figured out how to fix yet
