Results 26 to 50 of 64
  1. #26
    …. I only changed to the GOLD plug on the Torx bolt for that reason. ...never had any issues with the Hex bolt …. and as others have said either the Dimple or Gold plugs are weaker than the solid OEM steel ones ….. but I am very careful about tightening them …. and yes I have had to go back and snug them a bit if I discovered any drips ( but not often ) …… Mike
  2. #27
    Sep 2018
    SE Florida
    Can someone point out which Gold Plug is right for the 1330 engine? Gold Plug doesn’t list Can-Am in its selections.
    TIA
    David
  3. #28
    Active Member Zoot's Avatar
    Mar 2019
    AZ
    <snip>
    I have no idea what the torque specs are on the drain plugs. <snip>
    You can find generic torque numbers based on the size of the bolt and the thread pitch. Look for a chart on line (Fastenal, Bolt Depot, etc.), or in Machinery's Handbook. At least you'd be in the ballpark.
  4. #29
    Aug 2019
    Stoughton, WI
    From my 2019 manual:
    TIGHTENING TORQUE
    Drain plug (oil
    sump cover)
    28 N•m ± 2 N•m
    (21 lbf•ft ± 1 lbf•ft)
    TIGHTENING TORQUE
    Magnetic drain
    plug (clutch cover)
    20 N•m ± 2 N•m
    (15 lbf•ft ± 1 lbf•ft)
  5. #30
    Florida Swamp
    Quote Originally Posted by DavidJS View Post
    TIA
    David
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    2019 F3-S , Black & Silver
  6. #31
    Sep 2018
    SE Florida
    Thank you!
    David
  7. #32
    Jan 2019
    Kentucky
    Drain Plug (oil sump cover) [Riders Left Side] 21 lb-ft +/- 1 lb-ft
    Magnetic Drain Plug (clutch cover) [Riders Right Side] 15 lb-ft +/- 1 lb-ft
    Oil Filter Cover 18 lb-ft +/- 1 lb-ft
  8. #33
    Feb 2012
    Spring City,Utah
    If you decide to put hex head plugs, check with Value Accessories they are quality parts and $5.95
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  9. #34
    Aug 2019
    Stoughton, WI
    Nice tip .. BP5-303 Thx
    It is also part # 0712-0551 thru your local Parts-Unlimited dealer. MSRP is $10.95
    http://store.valueaccessories.net/Ma...rainPlugs.aspx
  10. #35
    Active Member ChicagoSpyder's Avatar
    Chicago
    TIGHTENING TORQUE
    Drain plug (oil
    sump cover)
    28 N•m ± 2 N•m
    TIGHTENING TORQUE
    Magnetic drain
    plug (clutch cover)
    20 N•m ± 2 N•m
    With people talking about what a fight it is to loosen the plugs you have to think at those relatively low torque settings that they have a gorilla in Austria who doesn't have a calibrated air torque wrench sending those plugs home.
    2018 F3 Limited , Black/Chrome
  11. #36
    Mar 2017
    Pardon my ignorance, but are both plugs the same size so buy 2?? Listing says
    BP5-303, M14 x 1.5 Fits:
    Main Engine Reservoir Spyder 1330, 14+ (Extended Magnetic Oil Drain Plug)
  12. #37
    Quote Originally Posted by Rattlebars View Post
    In the 1330 engine the two oil plugs are different , maybe the same thread size , but physically different ….. hope this helps …. Mike
  13. #38
    Florida Swamp
  14. #39
    Mar 2017
    Not really helpful but thanks.
    Quote Originally Posted by Gwolf View Post
    Nice pics. No details tho.
    Parts list shows engine SCREW M14 X 1.5 with oring grooves 420441681 and clutch cover Magnetic Drain Plug M12 X 1.5 42024178 . so Gwolf shows the right pics so I would guess .... one m5-302 and one m5-303. But I don't like guessing. Bear in mind, I changed my oil three months ago so I don't remember (even if I did it 15 minutes ago I would not remember ).
  15. #40
    Florida Swamp
    There are several different after-market magnetic drain plugs. When you start looking for them, you will find them listed by which Spyder engines they fit. They are all pretty much the same shape and threads as the stock plugs. The difference is they have a hex head on them and a magnetic plug in the end. Search by which engine you have and you will find the right ones. Some of them have different stock numbers, so not much sense in listing all the numbers. The seller will have the year and engine size the plugs fit in the specs for them.
  16. #41
    Dec 2012
    Murphy, NC
    If you order Gold Plugs the drain plug for the 1330 engine is MP-18. The drain plug for the 1330 transmission is MP-01.
    2020 F3 Ltd
    Spyderpops Bumpskid
  17. #42
    Mar 2017
    Quote Originally Posted by JKMSPYDER View Post
    Thanks!
  18. #43
    Feb 2020
    Austin
    Be carefull hammering the casing it is probaly made of aluminun and easy to breake a chunk out!
  19. #44
    Active Member ssmcclub's Avatar
    Apr 2013
    massapequa ny 11758
    what mm socket for the gold plugs mp 01 mp 18 ?
    richie spyder
  20. #45
    Jul 2018
    Saskatchewan
    There are specific rods for this exact reason... https://www.lawsonproducts.ca/pdfs/P...Removal_PI.pdf
  21. #46
    Dec 2012
    Murphy, NC
    15 mm for the left side and 17 mm for the right side.( as sitting on the Spyder)
    2020 F3 Ltd
    Spyderpops Bumpskid
  22. #47
    Apr 2013
    massapequa ny 11758
    thank you jkm spyder
    richie spyder
  23. #48
    Mar 2019
    Ruidoso Downs, New Mexico
    I realize this is an old thread but I've discovered that at some point since 2019, they apparently replaced the 6mm hex drain plug with a T40 torx. Not any easier to get out though......I'm struggling now with the little bolts that hold the plastic cover on, one of them is so close to what appears to be a ground point that I can't get a box wrench on it! Taking a break now to restore some sanity. This my first oil change at 2000 miles (I know, there is no need to do it now but I want to!) and everything is factory tight!
    2020 F3L; gone but not forgotten are all the good miles!
  24. #49
    Mar 2019
    I haven't quite given up but pretty close.....plastic piece out of the way, got on the plug with a vice-grip but no luck! Tried a little heat with a heat gun (afraid to get things very hot, wiring close by), still no luck. I've beat on it with a hammer, driven both a T40 and a 6mm into it, hole is now pretty much round. Still not loose. Now what? Drill and tap for an easy out I guess.
  25. #50
    Mar 2013
    Marion, Arkansas
    If you can't get a good hold with vise grips then I think a drill and easy out is next. Good luck.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
