Grease Fitting
Broke half of grease fitting off of top of A frame. Are they metric or standard where to get one
Thanks for the help.
They're standard metric - 6mm.
The best substitute for brains & knowledge is....................silence.
As stated they are metric.
Harbor Freight has a nice assortment box of straight, 45 & 90 degree fittings.
The Power of Logic.
Start Thinking.
Recently replaced all 8 grease nipples on the front A arms with M6 x 45 degree nipples, only problem I had with my 2011 RSS was that I had to drop the top A arms an inch to install the back nipple.
There was not enough room on this model to swing the grease nipple without it hitting the tapered gusseting plate just above the rear pivot point, once screwed in no worries, it clears everything.
You may need to get a couple of thin washers to shim the grease nipple so that it points outwards.
Now easy to grease with a standard flexible hose grease gun.
grease fittings
You should also be able to find them at any auto parts store.
All the great movements in the world began with a cup of coffee!
2018 F3-T
My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
How Often
How often do the fittings need an application ???
Willie
grease
What type of grease is everyone using?
Willie
I see you have a 2015 model. So for you never.
2018 F3 LIMITED
Found some at Napa that were short like the old one. It took for ever to put it.
