Results 1 to 19 of 19
Thread: F3 rear wheel ?
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    Default F3 rear wheel ?
    will an F3 rear wheel fit my rts. is it just a silver version of my black one ?
    already have the fronts. --thank you for any help
    pretty sure they are the same but need guru stamp on it.
    [joyce & irvin toms]
    Default Little checking..
    If you are talking about. F3 2015 and RTS 2015 they are the same part number...the numbers will vary according to color or type...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    They'll fit...
    United States
    Dumb question. What about the sprockets? Thought the F3 had the smaller sprocket.
    Houston
    Quote Originally Posted by Doc Humphreys View Post
    F3 has a larger sprocket. Either sprocket will fit the wheel but you cannot put an F3 large sprocket on an RT or vise versa. Nanny will complain LOUDLY.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    May 2016
    mt morris il
    so my stock 15 rts sprocket will screw up the computer if used
    with the silver F3 wheel ? thought they just bolted on.
    United States
    Yep, my bad. Large sprocket = lower gear ratio.
    If it bolts up, reusing your original sprocket and the new rim should be no problem and work fine. Make sure you use loc-tite on those sprocket bolts and torque to spec.
    Quote Originally Posted by Joyce47 View Post
    No! Your bike will be fine, and long as the sprocket is the correct one for the bike.
    Houston
    Your stock RTS sprocket will work fine with the F3 wheel on an RTS.
    Houston
    There are no bolts holding the sprocket on the wheel. Its a press fit in the rubber isolators and the axle bolt goes all the way through.
    Easy-Peasey!
    May 2016
    mt morris il
    say what!! what keepi from turning by itself? better look at a parts pic.
    United States
    http://www.cheapcycleparts.com/oempa...ve-system-rear
    No bolts, just the damper from what i can see.
    May 2016
    mt morris il
    no wonder they dont want or let us do burnouts !!!
    update. aaahh, i see the hub has slots for the damper. i thought it
    just sat in there and was pressed in to a round opening. my bad .
    Houston
    I am intimately familiar with the assembly of the rear axle, both older 2 piece and newer one piece versions. Having done multiple sets of rear bearings and a great many tire replacements and brake jobs.
    The forward thrust is transferred from the sprocket to the wheel via the rubber damper blocks in between the metal webs of the two castings. The sprocket and wheel engage each other via a press fit.
    Houston
    Have no idea why you would think that. The new 2017 F3S allows all the burnouts your tire budget can afford. Same rear wheel assembly. The design is simply not a weak link and is there to absorb vibration from the belt and engine as the thrust is applied to the wheel where you would feel it. Its actually a pretty robust design.
    If you look at the parts; you'll see that there's plenty of "meat" in them!
    May 2016
    mt morris il
    so what besides the standard F3 got the silver rear wheel? someone had posted
    all 3 wheels for sale. i already have the silver fronts. thought the y might sell
    the rear by itself.
    Jul 2011
    Mitchell, Ontario, Canada
    I am assuming you are wanting the 705502089 Metallic Silver Rear Rim. 6 spoke. That may come as standard on F3, RS, ST, RT, 2015 and later. The matching 79 tooth sprocket is 705502015 Silver Pulley Ass'y. 3 spoke.
