2013RT LTD Oil Usage
My dealer says the 996cc engine should use about 1 qt every 4700 miles. Could I get a confirmation of this from other Spyder riders?
thanks, Diggerdog
My 2012 never used any measurable amount of oil between changes. I also made sure it had a proper warm up before running it hard. I am convinced that it made a difference. I have a friend with a 2012 also and his doesn't seem to use oil.
2000 miles through Adirondacks and Vermont. No measurable change on the dipstick. 32000 miles on the engine. Just be sure to always check the oil with the oil hot after a ride.
Doug
”Freedom is not a loophole”
oil usage
What your dealer told you is correct; I normally will use a quart between changes. I would expect 2-3 oz / 500 miles traveled. The new triples don't seem to use oil by all reports.
2018 F3-T
Will vary....
I have a RS 2012 sm5 and I don't use that much but they all do use oil. Many who will mention no use will be ryding the 2014 /15/16 1330 engines. Your dealer is right but the amounts will vary.
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
I can confirm that my 2013 RT consumed a quart of oil between oil changes.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
I don't even notice, but we must be alert on this matter coz it might bite your **** if you ignore.
2012 Spyder RT SE5 Brake pedal mod
I use a our 1/2 quart at most between changes on my 2013 RT Ltd.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
My previous 2012 RT used a quart between oil changes. Of course, I rode her hard.
Current Ride
2015 RT-S SM6 Cocaine
Pearl White
Diamond R Web Armrests
Shorty Windshield
Previous Ride
2012 RT SM5 The Beast
Pure Magnesium Metallic
Ozzie Ozzie Ozzie
Banged Up Member
My "13" used anywhere from 1/2 to a full quart for every 4,700 miles.
Chris
Oil usage
My 2012 RT Limited uses about haif qt. between changes.Maybe a little more if I am pulling my trailer a lot.
Same here...
thanks, Diggerdog
Samething for our 4 Spyders... and high rev and hard riding use more. Low rpm shifting also do use more....
Richard
Richard
* 2012 RS SE5 (hers)
* 2013 ST SM5 (mine)
Daughter RSS SE5 2014
Son in law RSS SM5 2013
P.S. 3 Kumho AST 225/50R15 and 1 Toyo Proxies 4 225/50R15 rear tires
2 sets of Kumho 175/55R15 front tires
1 set of Hankook V4
1 set of Canadian Tire General tire Evertrek RTX in 14" for the 2012 ...
Gratitude
Thanks to all fellow Spyder riders that responded to my inquiry about oil usage on my 2013 RT LTD. I will heed all the remarks...
Diggerdog
I find I use oil when pulling the trailer and not much other times
