Results 1 to 18 of 18
    Linden, CA
    Default IS your BUTT SORE ????
    I have been making full custom seats on
    stock seat pans since 1967 we do it every day
    BUT you can improve your stock seat by about
    a zillion % by installing one of my custom made
    seat Gel kits with memory foam and save many
    hundreds of $$$$$$$$ You do it your self.
    There are a bunch of Spyder Riders right here
    who have done it and love it,
    The Gel kit is only $79.95 ... you don't have to
    wait 2 or 3 weeks you can do it in about 2 hours.
    Call me any time to get yours and save money
    and a big plus... you get to say I did it myself!
    Ride Safe
    Dave
    Active Member woodyaa's Avatar
    Mar 2015
    Harvard, Il
    Ride Safe
    Dave
    Will your gel kit work with a heated comfort seat? I'm sorry if this is already common knowledge.
    2015 RT-S
    Very Active Member DriftersWay's Avatar
    Jun 2013
    Uniontown, Pa
    I installed the gel seat and love it.
    Easy to install You just need to get the nerve
    to tear the seat apart.
    Butch
    2022 F3 Limited , Monolith Black / Dark
    Active Member ceyer69's Avatar
    Jun 2015
    Wake Forest, NC
    Default Seat Upgrade
    Are you going to the Spyder Rally in Maggie Valley, NC? October 2016
    2015 SE6 SS
    Elka Stage 2 front and rear shocks
    Lamonster Web Pegs
    General Altimax RT43 Rear Tire
    Lamonster LED Headlights and Fog lights
    Baker Wings
    Bajarons Sway Bar & Links
    Custom Dynamics Fender, Bright Sides and HMT Brake Lt
    Zumo 590
    CB
    Spyder Mudflap
    Lamonster drink holder
    Foam Grips
    Billet Axle Covers
    Stebel Air Horn
    SpyderPops Bumpskid
    SpyderPops belt guard
    SpyderPops Kotte Grills
    TriCLED LED Driving lights
    Magic Mirrors
    Jul 2015
    Dorr, michigan
    Sounds like a dangerous open ended question to ask.
    2020 RT Limited , Petrol Blue
    Feb 2012
    Spring City,Utah
    Another vote for Dave's gel seat pad. It turned a 2 hour seat into an all day seat for me. I had never done this type of work before but following Dave's instructions I made it thru and the seat looks like stock until you sit on it. Then heaven. You will need a power stapler to pull this off yourself. I bought one for $30 bucks but you may be able to rent or borrow one.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jun 2016
    Arizona
    Default Gel kit with heater
    Ride Safe
    Dave
    Dave, I thought I saw your gel kit somewhere where it had a cutout for the tailbone?
    That is the part that aches for me after a few hours - and when travelling for days accumulates into a very sore spot.
    Will the gel kit help with that?
    Also, If I am only doing the gel on the rider section, can I add your Moto heat to the passenger section or will that require a cutout?
    Lastly, your website mentions "Some of the newer seats on RT models use hog rings and not Velcro". Is that something that will complicate the process of reinstalling the cover? Will I need any special tool for that?
    Many thanks
    BTW - I have a 2016 RT Limited (with your BT option)
    Feb 2012
    Spring City,Utah
    Having been one of those with hog rings instead of Velcro to hold the back of the cover into the rear to keep that wrinkle free, I can say no it isn't a problem, you just can't pull it free like velcro. You do have to remove the hog rings which any pair of pliers will do. I did not replace the hog rings, I could not get them around the iron rod buried in the seat that they attach to. I had some rebar tie wire and used that, pulling it tight and twisting to keep it that way then used wire cutters to cut off the excess.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Linden, CA
    YES it will work, it is just a little more work
    maybe 15 min. time.
    Quote Originally Posted by woodyaa View Post
    2015 RT-S
    Linden, CA
    Default Not this year
    I would love to but that is over 2000 miles away and it hard to pack all that
    stuff on a plane.
    Quote Originally Posted by ceyer69 View Post
    Linden, CA
    Yea I guess that could have other meanings.......
    Quote Originally Posted by Fatcycledaddy View Post
    Linden, CA
    You did, I have done several like that, if you have a broken tail bone this is the only help
    I know of you will see pictures of it on my website in the photos section.
    You can install the heaters on front and back without any cutting of the foam, If installing
    Gel and a heater you just put the heater pad on top of the Gel.
    Hog rings and the pliers are at Harbor Freight maybe $5.00 you will need a power stapler
    Ace Hwd, Sears, Home Depot, Lowe's have elect. and air type also good for putting up
    Christmas Lights. Harbor Freight has air type for about $20
    Dave
    Quote Originally Posted by Denno View Post
    Many thanks
    Linden, CA
    Hey That's a great idea, and saves on buying a hog ring set at the store,
    good old Ford repair parts Bailing wire.
    Mar 2015
    Harvard, Il
    maybe 15 min. time.
    That's great news, thanks for the fast reply. Will the gel insert also work for the passenger part of the seat?
    2015 RT-S
    Feb 2012
    Spring City,Utah
    You should know,it was your idea when I called you about the hog rings
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Linden, CA
    Default Yes
    It will work in both places Zi have them made
    large so they will fit 99.9% of motorcycle seats
    if it's to large just cut it to size with sizzers
    [QUOTE=woodyaa;1159505]That's great news, thanks for the fast reply. Will the gel insert also work for the passenger part of the seat?
    2015 RT-S[/QUOT
    Linden, CA
    It was ??????
    I must have been on my game that day
    Feb 2012
    Spring City,Utah
    Don't be so modest you are always" on your game"
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
