Page 1 of 2 12 LastLast
Results 1 to 25 of 35
    Active Member _..stiffler..'s Avatar
    Feb 2015
    NB Canada
    Default 215/60/15 doesn't rub on RT?
    I'm going on a trip. Don't have time to order and wait for oem size tire.
    Bought a uniroyal tiger paw for $90 cnd. But this thing is alot taller than the OEM.
    People who have this size. 215/60/15. Are you sure it doesn't rub on the RT?
    thx
    Stiff
    Sent on Note 5 in Taptalk
    2011 RT Limited , White
    Get in touch with Mike (BLUEKNIGHT911). He's been using that size for quite a while now.
    Pragmatic Member Pampurrs's Avatar
    Mar 2015
    San Tan Valley, AZ
    I have the General AltiMAX RT43 - 215/60R15 and it has plenty of clearance under the fender. Deanna and a few other people have it as well, and will tell you the same thing.
    Pam
    • 2015 RT-S Special Series / Red & Black
    • Baja Ron Sway Bar
    • Utopia Backrest
    • F4 Customs tall and wide vented windshield
    • Stebel Super Loud Air Horn
    • Baker Built Air Wings
    • LaMonster Highway Pegs
    • SpyderPops Exhaust Block Off Plate
    • SpyderPops KOTT Grill
    • SpyderPops Belt Guard
    • Cat Bypass
    • Laser Alignment by Squared Away
    • TricLED Fender Lights
    • General Altimax RT43 rear tire
    • Dual flag holder
    • Mud Flap
    • A$$hole seeking missile system
    Feb 2015
    NB Canada
    Awesome. It looks huge. So I'm hoping. Thx for responses.
    Vermont
    I am running the same size ( General Altimax RT 43) 215/60 R15, on the rear, and I have plenty of clearance under the fender. This is my 2nd year with the General Altimax RT 43 on the rear of my . Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Oct 2015
    Orange City, FL
    Someone posted a few months back that the Tigerpaw was too tall and rubbed.
    As posted above, all tires are different sizes, even if they have the same size stamped on them.
    Personally, never cared for the Tigerpaw line. Always seemed more rounded instead of flat/square design.
    Hope that helps.
    Feb 2015
    NB Canada
    Quote Originally Posted by robertl View Post
    Hope that helps.
    This doesn't help Robert lol. J/king.
    I have the uniroyal tiger paw. That's the only tire I could find in this amount of time I have. The general altimax I can't get anywhere and if I can get it,it's back ordered and will take 3 months plus.
    So I guess I'll try this. I'll post a review.
    Thanks
    Stiff
    Mar 2015
    San Tan Valley, AZ
    Quote Originally Posted by _..stiffler.. View Post
    You can get it by Thursday
    https://www.amazon.com/gp/offer-list...&condition=new
    Pam
    • Baja Ron Sway Bar
    • Utopia Backrest
    • Cat Bypass
    • Dual flag holder
    • Mud Flap
    Feb 2015
    NB Canada
    I live in Canada. So that won't work. Plus we leave Friday for a 3000km trip. So I want to make sure everything is on and good to go. Plus if I need to check belt tension etc I can go to dealer and do it quick.
    Dec 2013
    You should be able to fit most 215/60R15's (altho as mentioned, there are some tires out there that might show that size but are somewhat bigger than all the rest??) I'm running a Kumho Solus KH17 225/60R15 on the rear of my RT with no issues.
    There's plenty of room for the 225/60 under the back of my 2013 RT Ltd, altho if I ride thru a patch of sticky mud, the collection of mud that gathers on the tread can sometimes make it look as tho it might rub, but it hasn't yet, so most 215/60's should be fine.
    Nov 2012
    North Las Vegas, NV
    I'm running a 215/60/15 Michelin Primacy on my 2012 RT for 19,000 miles and it does not rub. Plus it makes your speedo more accurate.https://www.tacomaworld.com/tirecalc...0r15-215-60r15
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jun 2010
    Las Vegas
    I think I've worn out my Altimax at 17,000 miles. It now says "replace tire" instead of "replacement tire indicator"
    EDIT: I checked my records and I only got 15,000 miles out of it.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Mar 2015
    San Tan Valley, AZ
    Quote Originally Posted by SpyderAnn01 View Post
    That's discouraging...... I was hoping to get a lot more than that out this tire.
    Pam
    • Baja Ron Sway Bar
    • Utopia Backrest
    • Cat Bypass
    • Dual flag holder
    • Mud Flap
    Nov 2012
    Pueblo Colorado
    Default Not too bad for a rear tire,
    We've got 18,350 miles on the wifes Kumho on her RT and its down to less than 2/32" usable tread. If we were in a "wet" area, it would be time to change, but with the original tread depth of 9/32" we can probably go another couple thousand until I have some down time to change it. Seems like we got around 23,000 miles on the 2011 SM5 model, but every bike is a little different.
    For pure wear, the Michelin Defender was the best on the 2011 RT with plenty of tread depth to start with and good tread still on it when we traded. If I didn't have a Kumho waiting in the garage, I just noticed that Tire Rack has the 215/60R15's on close out sale for 111 and change. We liked the performance on the old RT!
    2015 RT , OEM Black Gloss
    Jun 2010
    Las Vegas
    I checked my records and I've only put 15,000 miles on the General Altimax and the "replace tire" is showing.
    2010 RT- 622
    Default THE ALTIMAX
    Bummer, I was expecting better mileage from that tire .............what PSI did you usually run at ????......... I still have my Michelin Hydro-Edge ( and looooove ) with 15,000 and it is barely worn down, it has been excellent in the rain also........Mike
    Jun 2010
    Las Vegas
    28. Most of my miles are towing the RT-622
    2010 RT- 622
    Active Member GeorgiaBill's Avatar
    Aug 2015
    Marietta, GA
    Default Amazon tires
    Thanks, Pam, I hadn't thought about tires from Amazon. I expect the Altimax to be my next tire.
    Bill
    Quote Originally Posted by Pampurrs View Post
    2019 Black F3-T
    Sep 2013
    Houston
    I have had several cusomers with the 215/60 tires come in with rubbing problems in the rear near the fender/mud flaps. Its a much taller tires than OEM.
    We sell and install the Yokohama S Drive 205/55 15 as its an exact match to the OEM actual size and a GREAT running tire on the Spyders.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    That IS a real close match!
    My only concern: Do you think that the 205mm tire might come unseated from the rim a bit more easily than the 225 mm tire, if it runs low on air?
    Default LOW AIR PRESSURE
    I actually ran my 215 at 12 lbs doing test launches for Drag race purposes ......I marked the rim and tire first ......and they stayed lined up ......I don't think a 205 at 21 lbs is going to move .....jmho...Mike
    Default TIRE WEAR
    Interesting ........... I run my Michelin at 21 lbs. because it has much stiffer sidewalls ( as does the Altimax ) ...........The reason BRP and Kenda recommend 28 lbs is because the KENDA... NEEDS higher air pressure to support the weight.....Ask BajaRon He seems to know a bit about tires.......................Mike
    Thanks, Mike!
    Sine I'm the person who normally stays pretty well "inside the box"; I figured it best to ask...
    Default TIRE RUBBING
    JC, I have Mud flaps and so do many, many others here with a 215/60 tire. and they aren't reporting this as an issue....... So maybe the MUDFLAPS you are using are the problem ???????.................just a thought.........Mike
    Jun 2010
    Las Vegas
    I've never had any rubbing with my Altimax
    2010 RT- 622
