Results 1 to 14 of 14
Thread: GPS Lock
    May 2012
    North Las Vegas
    Default GPS Lock
    I am looking for the latest and greatest GPS lock. I know several have been discussed over the years. I just can't seem to find the current and most up-to-date discussion on the subject. I know you guys will help me out.
    Thanks,
    Rick
    USAF MSgt, Retired
    2018 F3 Intense Red
    Squared Away Lasar alignment, TricLED Headlights, Foglights,Safety Bundle with Turn Module, BajaRon Sway Bar,Squared Away Mirror Wedges, Stebel Air Horn, Dash Turn Indicators, TricLED USA Flag
    2018 F3L , Intense Red
    Jul 2014
    Mint Hill, NC
    The winner all around IMO: http://www.kradellock.com/
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    (And it's even pretty easy to install!)
    Active Member DRTSB's Avatar
    Feb 2012
    Ottawa, Canada
    Default GPS Lock
    I just use a plastic zip tie around the push button release, if you can't push the release button, you can't remove the GPS, cost pennies instead of hundreds, been doing this for 2 years.
    Dave
    2011 Spyder RT Limited, drive daily (except when it's snowing)
    2012 Honda Fury VT1300
    1974 850 Norton Commando, drive daily, praying that it keeps running!
    2009 Goldwing GL1800 AD, traded in
    2009 Suzuki M109, (fast bike), traded in
    2011 Nissan Murano SL, S, ride to work
    That may be true...
    But it only takes one determined , that has a pocketknife...
    May 2012
    North Las Vegas
    Just ordered KradleLock.... Thanks for the information
    USAF MSgt, Retired
    2018 F3 Intense Red
    Bossier LoUiSiAna
    Quote Originally Posted by DRTSB View Post
    Dave
    2yrs of zip ties? Do you cut & replace or wait till they degrade from the UV's? Think the Kradlelock is better option myself.
    I wasn't there but I still care! POW /MIA VETS
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Active Member Mikel53's Avatar
    Amarillo Texas
    Default Kradellock
    Mike Campbell
    Amarillo, Texas
    2015 RTL "intense red pearl"
    Once you install the Kradellock; the rubber cover that is fitted over the bracket when the GPS is removed, might not fit properly...
    I trimmed just the bottom "lip off of the top of it, and it slides underneath the lock much easier now!
    (although I rarely remove the 660 from my bike...)
    Bossier LoUiSiAna
    I know however after acquiring a KradelLock, learned they use same size barrel keys as Lidlox already mounted , contacted Bob & was able to get lock exchanged to match
    1 less key to loose/ confuse
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    I would look at Touratech lockable mounts for most GPS units
    https://touratech-usa.com/Motorcycle...ts-and-Devices
    Eddie Sheppard
    Poole Dorset UK
    Get a Spyder - See the World
    Jul 2014
    Mint Hill, NC
    Touratech has substantially cleaned up their designs since I bought my Kradellock in February 2016. At that time the Touratech was a much more expensive, still is now, ang IMO ugly "contraption."
    Cognac 2014 RT-S
    Very Active Member tofriendscreek's Avatar
    North Central Arkansas
    I use Zumolock for my Garmin XT.
    Simple, small and easy to install.
    https://www.zumolock.com/index.php/en/
    2022 Plasma Red, F3 Limited, Special Series
    Sep 2020
    Ontario, Canada
    Default Zip tie fix.
    I did this so I could not accidentally hit the button and lose the GPS (happened once, too expensive a lesson to repeat). Have since bought the ZumoLock.
