Results 1 to 8 of 8
    May 2016
    Orlando, FL
    Default Two brothers Exhaust Questions
    I ordered a Two brothers exhaust for my 2015 F3-S and received it this weekend. I have a couple of questions:
    1. Any tricks to removing the top Spring? It's being a PITA even with the included tool.
    2. Does the Lamonster Performance Pipe work with this kit? I'd like to remove the cat when I install the TBR pipe.
    3. Is a Power Commander absolutely necessary if I install the muffer and Performance Pipe?
    Thanks,
    Joe
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    3. Power Commander is NOT necessary. After installation allow bike to idle for 10 mins.
    AJ
    Quote Originally Posted by joeyvaz View Post
    Thanks,
    Joe
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    May 2016
    Orlando, FL
    Quote Originally Posted by PaladinLV View Post
    AJ
    Thanks, I read that just now as well. Now I just need to figure out how to get that top spring off. It's not cooperating at all.
    May 2016
    Orlando, FL
    What a PITA!!! I used a thick (12ga.) wire in my left hand and the spring tool in my right hand. I had to remove the bolt on the brake linkage at the rear so I was able to use both hands. Finally got the spring off. And it is all put together. Sounds real nice. What a difference in weight too!!!
    I hope my too handed approach helps someone in the future if they come across this post on a search.
    Active Member siny10309's Avatar
    Dec 2015
    Tropical Island ____________of Staten
    Thanks,
    Joe
    I was under the impression that the two bros come with the cat delete pipe. is that not the case?
    2015 F3 SE6
    May 2016
    Orlando, FL
    Quote Originally Posted by siny10309 View Post
    Yes it does. The Lamonster pipe is shaped differently from the Two Brothers mid pipe, so I was a bit confused. I thought the Lamonster pipe was a replacement for the front pipe. My bad.
    That being said, the Two Brother's system is LOUD-especially when on the throttle. I'm trying to figure out if the baffle Lamonster sells will work with the Two Brothers set up. If it does, it's worth a try. Not to mention I feel some mid range throttle response missing now that I've installed the new system.
    Active Member Hey Yu's Avatar
    Mar 2016
    Australia
    Why not use the two bros baffle? http://www.revzilla.com/motorcycle/t...-p1x-power-tip
    May 2016
    Orlando, FL
    Quote Originally Posted by Hey Yu View Post
    I didn't even know they had one. Theirs seems to just lower DBs. The video doesn't state if they also help to get back the mid range torque I seem to have lost. I'm ordering a bunch of stuff from Lamonster so I'm just going to order the baffle there as well. I just want to make sure it will work with the TBR exhaust before I do.
    Thanks
