First Syder code flashing.
We have a 2014 RTL. What does it mean when you have a flashing symbol that looks like your spyder orange on the bottom of your screen ?
THE FLASHING
More info would help narrow the possibilities down and prevent wrong answers!!!!!!.....MIKE
In spot A, B or both.
2018 F3 LIMITED
Pragmatic Member
If it's a icon of a motorcycle with squiggly lines behind it, in the 5 O'Clock position on the the right side, it's the Nanny Light. It flashes on briefly when the Nanny doesn't like something that you just did. Go really fast around a corner and watch, she'll light up. It basically means the VSS is engaging. If that's what it is, nothing to worry about. Mine flashes often when I go around turns while accelerating.
Pam
- 2015 RT-S Special Series / Red & Black
- Baja Ron Sway Bar
- Utopia Backrest
- F4 Customs tall and wide vented windshield
- Stebel Super Loud Air Horn
- Baker Built Air Wings
- LaMonster Highway Pegs
- SpyderPops Exhaust Block Off Plate
- SpyderPops KOTT Grill
- SpyderPops Belt Guard
- Cat Bypass
- Laser Alignment by Squared Away
- TricLED Fender Lights
- General Altimax RT43 rear tire
- Dual flag holder
- Mud Flap
- A$$hole seeking missile system
Flashing icon
One time on mine it was the seat switch. Could be the VSS though, so cross your fingers it's the seat switch or the fuse.
Bob, k7xi. 2013 RTL
Our 2011 RT done that code when we went around a curve to fast and my wife was leaning the wrong way with the bike. It didn't lose power but we had to stop at a school and reset it. Just cut the bike off and pull the key out of the switch for about 2 or 3 minutes then put the key back in and restart the engine. All was good to go again. Ride Safe
If you leave your trunk unlatched it will flash too but you will see a statement saying that it is open.
One of the hardest decisions you'll ever face in life is choosing whether to walk away or try harder.
It's in spot A
Originally Posted by billybovine
IT happend after we started it up. A little orange picture of the spyder flashing on the bottom of the digital screen. My wife drove it to church and when she got back today she said it went off.
Some part of VSS system has a problem. Since it showed up at when the ignition was turned on. May be a self test failure. That is more of a guess. If it happens again. Get the code. Or get the dealer to get the code at the next service.
2018 F3 LIMITED
Thanks to all of you. New Spyder owner's can always count on the people in this fourm
