Adjusting shocks problem on RT
Have a 2013 RT Ltd. pushed the shock adjust paddle and "Manual Adjustment" popped up on the screen not the usuall Soft/Firm bars. Anyone else encounter this? Resolution?
2021 Sea to Sky, 2013 RT Ltd, 2005 Bombardier Outlander ATV
Your air compressor stopped working maybe time for replacement, see if you can hear it working
+1 on the compressor. Frequent problem,usually fixed under warranty if you still have some. If not search this sight for the threads on an aftermarket compressor. Better quality and cheaper.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
If it's not the compressor; the strut that monitors the ride height may have somehow gotten loose...
Take a look at the LH side of the swingarm: just about where the bodywork starts making it tough to see things.
The strut is up in there.
Same thing happened to me. Change the compressor Under the warranty. My dealer told me it was a 600 to 700 $ (canadien) to do the job. Just cost me 50$
Mine was making a lot of noise, got it changed under BEST warranty.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
Yes I had to change mine under the Zurich warranty. Same $50.00 cost. Deal said the strut was not working properly and caused to compressor to run too much and burn out. There is also a relay switch there that can short out if it comes loose from where it is mounted and that will cause the same thing.
Happy TRAils/NSD
Paul
2012 RT L
TRA
PGR
Venturers #78
TOI
