Results 1 to 4 of 4
    RT-S PE#0032 2Gunns's Avatar
    Oct 2009
    North Carolina Sandhills
    Default broken mirror bracket on 2010 RT-S
    Is it possible to buy (and if so where) the insert brackets on the backside of the mirror. I have managed to break the top one (one without the metal clips). The inserts are held in by two little screws.
    Spyder Bytes: Kury ISO Grips, GL1500 Windshield Vent w/ accent, Heel-Toe Shifter(inspectorgadget), HMT Brake Light, 12v outlet in frunk, GPS-Phone mount w/ case(techmounts.com), seat seal, Right Side Grill Covers(customdynamics.com), Fan Can10(ISCIrides.com), CAT Shields(SpyderPops.com), Elka Shocks, PressurePro TPMS, Cobra CB....and of course Cup Holders(mycupholders.com)
    Jul 2014
    Mint Hill, NC
    Go to this web site and drill down for your model Spyder and find the parts. You can order them online from BRP, from your dealer or from Cheap Cycle Parts.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Sep 2014
    USA
    Yes you can as I keep a spare set just in case..
    Nov 2013
    Central Texas
    Default MIRROR CLIPS
    http://www.cheapcycleparts.com/oempa...sories-console
    On the parts diagram the upper housing clip is 60D part #219800158. This is the one that most commonly breaks. Buy several and carry two with you and a torx screwdriver for a roadside fix. The lower housings are 60B part #219800156. These last much longer, as they are less prone to breakage, although the wire clips can become distorted over time. I carry a couple of these with me as well, just in case. This is a really easy fix.
