Page 1 of 2 12 LastLast
Results 1 to 25 of 27
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    Default FBB orNBV highway pegs
    which do you have and why did you buy these over the others?
    gotta get some to help relieve pressure and pain to certain body parts.
    im kinda leaning toward the floorboard mount. help!!?
    thank you --irv toms,[15 rts]
    2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
    and some little stuff. setback utopia backrest, baja ron
    sway bar, oem adj. air deflectors, marlin gps compass,
    lamonster fbb foot pegs[modified brackets], lamonts
    vibration damper, rock guard, and side case stiffener kit,
    . brp comfort seat. , fomozas and
    altimax, magic mirror mts, and wide mirrors.
    [joyce & irvin toms]
    Active Member JayD's Avatar
    Oct 2015
    Cumming, Ga
    FBB is for the auto transmission
    Sent from my SM-N900V using Tapatalk
    2014 Spyder RTS
    Tri Axis Handlebars
    Big Bike Trailer Harness
    Rivco Front Bumper (Black)
    Rivco Highway Pegs
    Ultimate Seat
    Garmin GPS
    Trailer Hitch
    Aluma XL Trailer
    Stainless Grill Covers
    Cupholder
    Spring Stiffeners
    Rivco Floorboards
    Pragmatic Member Pampurrs's Avatar
    Mar 2015
    San Tan Valley, AZ
    I have the FBB. I think the reason I chose those is because the floorboard mount seems a bit more stable than the other. I may be wrong, but what can I say. Installation is fairly simple, you just have to remove the rubber mat on the floorboards and drill a couple of holes in the bottom of the floorboards. Some people here are squeamish about drilling holes for some reason.
    I'm sure you'll get a lot of varying opinions on this topic. Good luck with your decision.
    Pam
    • 2015 RT-S Special Series / Red & Black
    • Baja Ron Sway Bar
    • Utopia Backrest
    • F4 Customs tall and wide vented windshield
    • Stebel Super Loud Air Horn
    • Baker Built Air Wings
    • LaMonster Highway Pegs
    • SpyderPops Exhaust Block Off Plate
    • SpyderPops KOTT Grill
    • SpyderPops Belt Guard
    • Cat Bypass
    • Laser Alignment by Squared Away
    • TricLED Fender Lights
    • General Altimax RT43 rear tire
    • Dual flag holder
    • Mud Flap
    • A$$hole seeking missile system
    "Each to their own notion.", said the old woman as she kissed the cow.
    We really can't tell you which one might be better; It's your money, and your decision!
    For the record: I put Baker Builts on my RT!
    Why? I'm not sure...
    I was looking at their belt tensioners, and a funny thing happened...
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    I went with the NBV. From the looks of the videos, they stick out less than the FBB. I have mine adjusted to be just above the plastic air diverters, which would have been the natural place to put my feet. (For me, at least)
    2020 RT Limited , Marsala Red
    Active Member Brian Kay's Avatar
    Jul 2014
    Kennesaw, GA (Atlanta Area)
    Quote Originally Posted by Joyce47 View Post
    If you have a manual transmission, like I do, you have to go with the NBV ones. They do the job and fairly easy to install. Good luck!
    Brian Kay - Kennesaw, GA
    2014 RT-S SM6 Pearl White (KHAOS)
    TricLED 3rd and 4th Brake Lights - TricLED Turn Signals - TricLED Side Fender Lights - Airhawk R Seat Pad - Smoothspyder Belt Tensioner - JT's Dash Mount - JT's USB and 12v Power Unit - Stebel 139dB Multi Sound Horn - Lamonster NBV Highway Pegs - BRP Adjustable Wind Deflectors - Cal-Sci Stock Extra Wide Windshield - Baja Ron Sway Bar - WrapMySpyder 1330 Triple decals - Ultimate Tallboy Seat - BRP Sat Radio - ELKA Stage 2 Front Shocks
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    I use the RIVCO because they gave me more versatility and stretch for my 6"1" body
    http://rivcoproducts.com/shop-by-mot...oorboards.html
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Quote Originally Posted by PaladinLV View Post
    AJ
    Active Member lwrydr's Avatar
    Sep 2013
    Olympia, Wa
    Default modified risers
    here is a pic of mine....
    Very Active Member OverHillAndDale's Avatar
    Sep 2014
    United States
    Default I've had both
    I bought the FBV initially because they looked (and were) straightforward to install. However, they require that you really spread your feet far apart when using them.
    SO, I bought the NBV and sold the FBV (to Bob I believe) and like them MUCH better. Installation was not as easy but not bad, and they sit much closer to the sides of the bike.
    2020- RT Limited
    Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Big Bike Parts wiring harness
    Permanent Smile!!!
    Active Member Boilermaker's Avatar
    Sep 2015
    Muncie, Indiana
    Default Neither Allow You to Stretch Out
    I have the Lamonster NBV because they are closer to the body of my RTS, but at only 5'9", all they do is allow me to move my feet up and a little forward. You will not stretch out if that is your goal. It does at least allow you to change your foot position and I have gotten pretty imaginative on how I place my feet on the pegs.
    Mar 2013
    Marion, Arkansas
    Quote Originally Posted by Pampurrs View Post
    Pam
    Pam, I don't know how tall you are but didn't the FBB pegs just spread your legs to far out? Is it comfortable in that position for a long time? I have been kicking it around as to which ones to buy, since I'm 6'2" I need the extra distance to stretch my legs but not sure if I would like to have my legs spread apart that far. Thanks in advance.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Mar 2015
    San Tan Valley, AZ
    I'm 5' 8" so my needs are different than yours. I don't feel like my legs are spread. They pretty much just hug the contours of the faring.
    Pam
    Sent from my SPH-L720T using Tapatalk
    • Baja Ron Sway Bar
    • Utopia Backrest
    • Cat Bypass
    • Dual flag holder
    • Mud Flap
    Would it be possible to use a "stub-peg", and turn it toward the bike; rather than outward?
    Sep 2014
    United States
    Yes - I have the elongated peg to outside, the stub to the inside.
    Sent from my SM-T710 using Tapatalk
    2020- RT Limited
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Permanent Smile!!!
    May 2016
    mt morris il
    the nbv"s intrude into the limited amount of footwell that you DO have.
    i would still like to keep that. and that is a good point about neither allowing you
    to stretch out. that would mean removing or modifying the deflectors. guess
    you cant have both. or can you . cmon you innovators . stretch the possibilities!!
    Baker Built...
    I know that it's not on your radar, but here's where the pegs put my feet...
    Sep 2014
    United States
    The issue with ALL the highway pegs is you can't sit like you would on a cruiser or touring bike because the Spyder flares out so much in front of the floorboards. Bob's look like they sit right where my NBVs go. Ursamajor had some Baker Built and they were more forward but also flared out to the sides. The sitting position on the Spyder is just different.
    With the NBV I can rest my feet on them for short intervals, or stretch out and rest the back of my heels on them.
    I think that the F3s allow you to sit with your feet closer together since the body panels that cover the engine on the RT aren't on the F3.
    2020- RT Limited
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Permanent Smile!!!
    May 2016
    mt morris il
    i like to stick my feet as far forward behind the black deflector as i can.
    the floor board mt seems to be the closest thing available for that reason.
    if i had wanted my feet back i could have gotten a goldwing. my victory
    cross roads had huge floorboards and you could really stretch out and
    didnt even need pegs. the rt is more like a wing with your feet tucked back.
    just looking for option to improve my riding experience and keep strap steel out of
    the foot planting area. [no im not trying to grow a crop of feet].
    thank you for all your help and opinions. i know you are enjoying your rides your way.
    they still have that freedom in America yet. happy 4th wekend to all and ride safe.
    --irv and joyce toms
    I have other brackets that moved my feet further forward. I removed them, and opted for a bit less stretch.
    Mar 2013
    Marion, Arkansas
    How tall are you Bob? The other brackets, what mfg. are they? I was looking for something to go past the black deflecters so as to not interfer with the floorboard brake away feature. Being 6'2" I just need something so I can stretch my legs.
    I'm about as average cab get: 5'10", and a 31" inseam.
    Baker offers two different brackets for mounting the pegs, You can hook them together, for a more forward position.
    That's how mine came, but I didn't need quite that much "stretch".
    If somebody needs my extra brackets: PM me!
    Mar 2013
    I started with the floor board ones and I clamped them on as a mock-up to see how they would work before I mounted them. Realizing that they would spread my legs out to far to be comfortable I worked out a deal to trade them for the NVB. I then made my own foot pegs out of 1/2" round aluminum bar stock drilled and tapped them and covered them with bicycle hand grips. This way I could get the pegs as close to the Spyder panels as possible. I am 5'8" with a 30" inseam. If I need to stretch out my legs I rest my heals on the pegs.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    AJ
    I went with the RIVCO ones as well, for the same reason. HERE is a review of them, with pictures, that I posted a little over a year ago.
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
