Led bumpskid issue
I have had the led bumpskid about a year and has low hrs but I have leds burning out.... It looks kinda crappy with the burned out black spots....
mark
Bullies are sad pathetic People
I have heard this happening. Problem is no one posts these problems with some of these aftermarket products so the next person has the information to purchase or not.
A LED Replacement kit is available from Spyderpops for about $40.00
Cruzr Joe
Cruzr Joe
I was just there looking myself don`t see them
Leon
2022 marsala red RTL
AND
2014 RT S SE-6 COGNAC, 2010 RT 622 TRAILER TIMELESS BLACK
BRP trailer hitch, Utopia back rest, Baja Ron sway bar , heim links. Elka stage 2 shocks front and rear.
TricLed fender lights, saddlebag lights and mirror lights. LED headlights and fog lights, Wide vu mirrors.
spyderpops LED bumpskid ,zippered cargo bag linings, Laser Alignment by Netzleys Tire, Stebal air horn
stant gas cap,( Dimple oil plugs REMOVED ) JT dash mount.
(Onboard) Lamonster Garage air compressor and intelliboost charger.
Who did you buy it from? Give them a call and let us know what happens. Chances are they will replace it free but you have to do the labor of installing the replacement led strip.
I am waiting for number two replacement strip.
Doc Riverside was investigating these reports. Why not PM him, and see if he's learned what is causing it?
talk to spyderpops, he is great guy & will work with you
I agree Harvey from Spyderpops is the best
2015 RT Limited Black Matallic
BAJARon Sway Bar w/Billet Aluminum Heim Joint Link Set
SPYDERPOPS Bumperskid with LED's
SPYDERPOPS RT BRT Rear Lighting Kit
US LED Flag
Leon
Just call Spyderpops at 501 627-4008 and tell him you want to order a LED Bumpskid replacement kit.
Cruzr Joe
I sent an email and have not heard back from him yet..
mark
Cruzr Joe
Not sure if I want to spend 40.00 a year on a new light strip.... Seems the me that LEDs should last more than 20-30 hours
mark
I am curious, do you find the LEDs going dark individually or in small groups?
mark
He is at a Spyder Event in Florida until Monday, he will respond.
Cruzr Joe
mark
Not trying to be a Smart *** but lights are affected by many things, Rain, Heat, Abuse etc. The nice thing is that you can remove the lights and still have the protection of the bumpskid.
I have had to replace some LEDs on occasion and do so because i want to be seen when riding.
Cruzr Joe
Are they the inlaid or not?
if a rock or thing else hits them in the right spot some will go out.
4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
they are inlaid, but they take a lot of abuse (or at least ours did) in that location. I even ripped the center lower lip of the grooved part of the bumpskid off on a cattle guard (split the LED strip in half while I was at it).
We ended up pulling ours out and decided to go with the cyclops LEDs instead. They've held up better.
We now have His and Hers Spyders!
Current Spyder: White 2015 F3-S SE6
His Spyder: White 2015 F3 SE6
Previous Spyder: 2012 RT Limited SE5 -- 30,300 miles
Previous rides: Kawasaki & Honda
Spyderpops
I also have had a great experience with Harvey from Spyderpops! He helped me out big time!
2015 Spyder F3-S
2021 Marsala Red Metallic RT Limited
