Results 1 to 14 of 14
    Registered Users barryj's Avatar
    May 2015
    Bellmawr, NJ
    Default Sway Bar install Question
    I have everything apart and I was trying to jack up the 2013 RT to the required height and it just is not happening. I could add blocks to the atv jack to get the required height but do not feel safe that way. I was trying to find a place that rents lifts or a ramp I could put on a wall I have but I cant find a place to rent them in south jersey.
    How far can I ride the can am without the sway bar attached, If I can get it to a gas station with a lift it would only take 5 minutes to lift and exchange sway bars.
    The alternative is to put it all together and ride 35 miles to can am dealer and have them do it all.
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by barryj View Post
    A standard ATV jack will not lift the Spyder high enough, as you have discovered. Most put jack stands under the A-Arms, lower the ATV jack, add some cribbing (4x4's, ect.) and jack again. You only need the Spyder this high for the bar swap. Once you have the new bar into the frame tube you can finish the assembly at a lower height.
    Bryant, Arkansas
    I don't believe you should/could ride it without any sway bar, but others will chime in here i am sure.
    Cruzr Joe
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    Do as Ron said. You'll be fine.
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    May 2015
    Bellmawr, NJ
    can I drive the bike with the sway bar unattached or should I put it back together to go to a friends garage a few miles away. Had it up on jack in my drive that is not level and did not feel safe.
    Invalid Emails
    Sep 2015
    Cheshire Ma
    Basically bar only really takes effect in the corners so take it easy in turns and you should be fine.
    May 2015
    Bellmawr, NJ
    Thanks all, I will let you know how I make out tomorrow.
    Invalid Emails
    Jul 2014
    Rotonda West,FL
    I put stands under the 3 points lowered the jack put 2 4x4 on the jack and took it up till i got the bar out and new back in
    Sent From my Note 5
    Aug 2007
    Greeneville, TN
    You can ride a Spyder without the sway bar attached. I've done it. You just need to be careful in turns. It will lean a great deal but it's safe to do. But I'm hoping you can jack the Spyder up a bit more. You're almost there.
    Active Member Upstater's Avatar
    May 2015
    Upstate NY
    I just used regular car ramps. Removed the frunk (not that hard) and had easy access with no problems. It's much easier to work on when the frunk is off.
    2012 Spyder RT SE5 Limited - Lava Bronze
    - Baja Ron Sway Bar - SmoothSpyder Belt Tensioner - Air Modification Kit - Motorcycle Dave's gel seat inserts
    - Rivco Floorboards - Show Chrome Trunk Rack - Bad Boy Wolo Air Horn
    - FZ-1 Fuzeblock - Hopnel Lid Nets - Monster Graphics
    May 2015
    Bellmawr, NJ
    Default Sway Bar install complete.
    All is well with the installation. I did not have to drive with the sway bar off, a good friend came over after work and helped lift it with the atv lift. I ran it up on ramps, slid 4x4's and a 2x10x14" on top of the lift and my good buddy had the great idea of stacking patio blocks under the rear tire as we jacked it up. The unsteadiness of the atv while lifting the whole bike made me nervous but the blocks under the back wheel helped stabilize it. I don't think we even had to lift it to the full height, slipped the old bar out and the new bar in with out a problem. Tightened all connections up while lifted and lowered to finish it.
    Took it for a short spin to outdoor concert then ice cream and it ran great. I felt a difference but bride did not. Tomorrow I will hit some more curves and enjoy the day, hope you all do also.
    Special thanks to Ron as in BajaRon for all the feedback both here and through email, holding my hand and calming the wife during the nerve racking process of trying to lift the bike. Really easy once you do it, just make sure you can lift it the required height...
    May 2015
    Bellmawr, NJ
    Quote Originally Posted by Upstater View Post
    whats a frunk? working on 2013 here.
    Mar 2013
    It's your front trunk, or frunk
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Aug 2007
    Greeneville, TN
    Apples and Oranges. Your's is a 2012. His is a 2013. No comparison between the 2 for the Install of the Sway Bar.
