Results 1 to 24 of 24
Thread: Starting Issue
    Invalid Emails
    Apr 2016
    Indiana
    Default Starting Issue
    Have a 2013 RT Limited. Has been running flawless since we purchased almost 2 months ago.
    Saturday we went on a charity ride and parked it after the ride. Jumped on the Syder this evening to take an evening ride. Won't start.
    The Spyder boots up and and appears to have plenty of juice. When you try to fire it up it clicks and flashes and won't start.
    Things i I have tried:
    Pushed in all fuses.
    Put foot on the brake.
    Checked the battery connections.
    Nothing but flashing.
    Any thoughts?
    Jul 2011
    Mitchell, Ontario, Canada
    Dead battery. Charge it and try again. Can't wait then boost it.
    2018 F3 LIMITED
    Hate to ask: Kill Switch???
    Pragmatic Member Pampurrs's Avatar
    Mar 2015
    San Tan Valley, AZ
    That was my first thought too, but he said it "clicks and flashes" when he tries to start, so I ruled that out.
    Pam
    • 2015 RT-S Special Series / Red & Black
    • Baja Ron Sway Bar
    • Utopia Backrest
    • F4 Customs tall and wide vented windshield
    • Stebel Super Loud Air Horn
    • Baker Built Air Wings
    • LaMonster Highway Pegs
    • SpyderPops Exhaust Block Off Plate
    • SpyderPops KOTT Grill
    • SpyderPops Belt Guard
    • Cat Bypass
    • Laser Alignment by Squared Away
    • TricLED Fender Lights
    • General Altimax RT43 rear tire
    • Dual flag holder
    • Mud Flap
    • A$$hole seeking missile system
    Invalid Emails
    Apr 2016
    Indiana
    Kill switch was off and had that whining noise.
    I am a new owner and have not bought a charger yet
    Guess I am screwed till tomorrow.
    Invalid Emails
    Apr 2016
    Indiana
    Okay. Read the manual and did the jump start method with the wife's truck. Started right up.
    So I am assuming it is a bad battery. Can anyone tell me a place to get a battery and how hard are they change.
    Mar 2013
    Marion, Arkansas
    I'd try jumping the Spyder off using another vehicle with jumper cables. If it starts its probably the battery going bad. Remember when jumping off your Spyder, the vehicle your going to jump the Spyder off with should have the engine turned off.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Invalid Emails
    Apr 2016
    Indiana
    So I just pulled the battery. Can anyone tell where I can pick up a replacement at a decent price.
    Very Active Member SteveLaoyster's Avatar
    Nov 2015
    Myerstown, Pennsylvania
    Default Battery Warehouse??
    Got a Battery Warehouse anywhere near you?? Don't know if they carry for the spyder but got a good deal for my softail. Good luck!!
    2016 RT-S , stock not yet Pearl White
    Idaho
    Quote Originally Posted by Gasman129 View Post
    You'll just have to look around, online and local. Try to get the same battery as OEM. They're YUASA brand and general consensus is they are hard to beat for the price. Take care of them properly and they'll last a long time.
    FYI, the battery has to put out at least 10.5 volts when you hit the starter. That's the threshold for the computer to be happy, and is quite a bit higher than what is needed to start many other bikes and vehicles. On your charity ride did you do a lot of slow speed riding? If so the battery may have just gotten sucked down too far. 2013 and earlier Spyders with the 998 engine do not put out a high enough charge at slow speed to really give a battery a good charge.
    2014 Copper RTS
    Default Well....
    Looks like they got you covered. One other thing..could there have been anything left on or charging off a power port that vould have drained the battery. ? In which case you may just need a good charge
    ​2012 RS sm5
    Invalid Emails
    Apr 2016
    Indiana
    Thanks for all the assistance. I do have one other issue.
    Last st nightni pulled the battery so I could take it in today. Well the schedule has changed and it may be a couple of days till I get a new one. So this morning I put the battery back in because I thought it might not be a good thing to lesve it unplugged that way.
    WHen i I turned on the bike I noticed that I did not get a boot screen. It went right to the regular screen and the bike fired up. Did I do something to the electrical system?
    Invalid Emails
    Apr 2016
    Indiana
    Just clarify. The message where you have to hit the mode button is the one that does not come up.
    Dec 2013
    ...... WHen i I turned on the bike I noticed that I did not get a boot screen. It went right to the regular screen and the bike fired up....
    if it starts & runs OK without any error messages, it's doubtful you did anything to the electrical system. What you have described sorta suggests that when you shut down last time it hadn't finished it's shut down routine before you pulled the plug; or maybe it hadn't completed the start-up routine before you pulled the battery out. Whichever, it could well be that your battery wasn't actually dead, but you only had a poor or dodgy terminal connection - & now you've re-installed the battery you've replaced that dodgy connection with a good connection, so it has completed the computer boot routine & started fine.
    If you want to see if this is the case, try turning it off, shutting down properly & pulling the key out, waiting at least 10 mins, and then try starting it & getting it running again. If the battery is OK & the terminal connections are now good, it should work fine & do the normal start up routine with the 'press mode' thing etc, in which case you can probably just proceed to ryde!! If it doesn't start up or do the whole boot routine properly, then you do probably have that dud battery you were working towards replacing anyway.
    It'll be interesting to hear what happens when you give this a try!
    Active Member Ex Winger's Avatar
    Apr 2015
    Brockville ONT
    For some odd reason these bikes will start with out having to push the mode button at times.Give the batt a good charge then load test it.
    Bill
    2018 RT Anniversary , Brake pedal extended
    I've seen that happen with mine several times, and there seems to be no ill effects from it.
    My bike is only on it's third Season on it's battery, and I've already noticed that cranking times are getting a bit longer. I will probably replace my battery at the end of this Season: just to be assured of no unexpected difficulties during NEXT year.
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    batterysuff.com is my choice. i always have a battery ready.
    yuasa has a generic brand made in the USA also. fast
    delivery. free ship. yuasas house brand is motocross.
    made in pa.--irv
    2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
    and some little stuff. setback utopia backrest, baja ron
    sway bar, oem adj. air deflectors, marlin gps compass,
    lamonster fbb foot pegs[modified brackets], lamonts
    vibration damper, rock guard, and side case stiffener kit,
    . brp comfort seat. , fomozas and
    altimax, magic mirror mts, and wide mirrors.
    [joyce & irvin toms]
    Jul 2011
    When the battery is disconnected for a period of time. The first start after reconnecting the battery does not require a press of the mode button. A normal quirk.
    Excuse me while I rant. What a stupid idea to push the mode button to start. BRP please fix this stupidity!!!!! Rant over.
    I must be missing something or you have not shared all the information. Why do you think the battery is bad? It certainly could be bad. But at this point I don't think you can know. Whether it is bad or not it needs to be charged up. If it won't take a charge. Then it's bad. If it takes a charge take it to a reputable battery seller. In my part of the planet they will load test for free. If it fails the load test. They will be happy to sell you a new one.
    2018 F3 LIMITED
    Very Active Member bronzeflex42's Avatar
    Sep 2014
    Sandersville, GA
    Just in case you still have to wind up replacing your battery. Cruzr Joe gave me a good place to get a battery. O'reilly's stock ETX18L is a good replacement. I had battery issues last week and bought that one and been doing great every since.
    2012 Spyder RT Limited Lava Bronze (Psalm 27:1;Luke 12:4,5)
    Jun 2016
    US
    Any thoughts?
    My ST Limited did that exact same thing. Found out battery died that quick.
    Sent from my SM-G925V using Tapatalk
    Jun 2016
    US
    Any thoughts?
    My ST Limited did that same thing and found out that my battery had died that quick. Replaced it 2 months ago and never a problem since.
    Invalid Emails
    Apr 2016
    Indiana
    Thanks for all the input.
    I had the battery tested and they said it was good. I think I will buy a charger. Looking at the optimate 3.
    Jul 2011
    Next step is to check the system voltage. Get out your volt meter or borrow one. Start your Spyder and let idle a couple minutes. Check the voltage across the jump start posts. It should be more than 14V. If not you may have a charging system problem.
    2018 F3 LIMITED
    Dec 2013
    It's sounding more & more like you just had a 'poor connection' issue on one of the battery terminals.
