Front end shake .. for no reason.
Has anyone had an issue with the front end shaking at about 35-40 MPH? It happened twice this morning on my way to work. Needless to say I turned around and went home. Didn't wanna get caught in afternoon traffic with a serious problem. This happened once before, at the same speed. I thought I had hit a pot hole. But this morning the road was smooth.... no issues with surface. Both fron wheels start the shaking like hell, once you let off the gas it mellows out. Any ideas? Spooky as hell that's for sure.
Thanks,
-Dave
Thanks,
-Dave
Bad tires or you need a rebalancing the tires
SpyderLovers Sponsor
Air Pressure
Thanks,
-Dave
I would check the air pressure. I had the same type issue and I went through the tire rebalancing which helped a little. Then I found out that I need my tire pressures at 21-22 psi to keep mine rolling smooth. Anything less than that I get the shakes from the front end. Any more than that the Spyder starts to wonder. This held true even after I had mine laser aligned.
2012 RTS
Do you have a tire sealant in the tires? If you do and it sets for an extended period of time it can settle and cause a shake until it gets redistributed.
MORE INFO
It doesn't happen all the time..... just all of a sudden today..... thanks for all for the information.... I'm gonna check it out when I get home this afternoon. It happened once before about three weeks ago.... I've probably put on 500 miles since the first time it did it.... now today, twice in about 3 miles....something's up Thanks again!!
-Dave
I get it about 65mph then it goes away
Sent From my Note 5
Shaking
-Dave
My 2011 LTD did this at odd times. Usually around 35-45 and seemed to happen after turning off side street from light and getting up to speed. Very violent shaking of both front wheels. If I slowed down or speed up it would stop. There was no consistency to it. I did have Ride On but it was not the session you get when Ride On is Cold in the tire. This was after the tires were warmed up. Never did find out why since I sold it. I suspect the tires were bad even though they did not have more than a few 1000 miles on them.
HokieV
2015 RTS Intense Red Pearl (New Jan. 2016) - Comfort Heated Seat w/Backrest, Custom Dynamics HMT Brake Light, superbrightled.com Brake Light Strobe, TricLED fender lights w/Blinker Module & Turn Signal Strips, Stebel Nautilus Horn, FOBO TPMS, Spydercuff, Dual USB outlet, Bike Barn.
Previous - 2011 RT Limited.
Thanks for the information....
My 2012 RT-L did this when I had new front tires installed. The problem was that they put all of the weights on the inside edge of the rim. The tire was balanced in a static state (single plane) but not dynamically (dual plane). Balancing is an art that many tire techs don't really understand. This kind of balancing error can easily lead to erratic wobble like you are describing.
Invalid Emails
My Motto Is:
Live my life in such a way that when my feet hit the floor in the morning...Satan shudders & says "Oh, crap, SHE'S awake!"
Red Stallion: 2016 F3t SE6 (from Pitbull PowerSports/ Springfield, MO)
White Knight: 2014 RTS SE6 and matching 622 trailer (from Pitbull
Ms Spydee: 2010 RT SE5
Pragmatic Member
Thanks for all of the replies and information folks. I don't think its a balance issue, or a tire issue..... Like I said it has only happened 3 times in almost 1500 miles. Scary as hell when it does happen. I just don't want it happening at 65 or 70 MPH!!! Both wheels, handle bars everything shaking side to side.... slow down and it stops.... take back off, get up to speed and everything is fine...... Weird....
At 35-40mph i doubt it is balancing
How about a busted "something", in a tire?
(like a belt?)
On a 2012, maybe it is time for "A" arm bushings. My service manager told me that when it starts to shake, it is time for bushings. On my 2012, they were a little loose but never cause a problem. Mine only had 14000 miles, however.
