Results 1 to 7 of 7
    Active Member Hitman5363's Avatar
    Jul 2015
    Azle, Texas
    Default LED Blinking on and Off??
    I installed LED's from TricLED on the rear fender of my 2015 F3S SE6 where the red side marker reflectors were. I also installed Blinker Modules under the passenger seat and ran the hot wires down to the new LED Red Marker Lights so they would Blink when the turn signals were engaged.
    Everything works perfectly....the rear fender markers blink when the turn indicators are engaged and they go off when I hit the brakes and they are lite when I am just riding down the road. The PROBLEM IS.....after I start the bike the Right marker light after 45 seconds to 1 minute begins to blink off and on........yet when I turn on the blinkers the right and left work.....but once the blinkers are off the RIGHT LIGHT..."ONLY" blinks off and on.....it does not Strobe it just blinks off and on. Reggy from TricLED and I have spoken and we are both at a lose.
    Anyone out there with Experience have any ideal why this is happening??
    Very Active Member IGETAROUND's Avatar
    Oct 2011
    Kalamazoo, Mi
    this sounds like a job for SPYDER CODES!!!!!!!!!!!!!!!!!!
    All the great movements in the world began with a cup of coffee!
    2018 F3-T
    My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
    2018 F3-T , Pearl White
    Default Polarity...
    One thing about LED's is they have to have the same polarity. This could be the problem but in any case it is in the wires somewhere...
    ​2012 RS sm5
    Jun 2010
    Las Vegas
    Why don't you send Reggy an email and ask him. sales@tricled.com
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jul 2015
    Azle, Texas
    Quote Originally Posted by SpyderAnn01 View Post
    Already did.
    Jul 2015
    Azle, Texas
    Will be looking at all wiring today.....to make sure the resistors ground and the blinking modules ground are the same. Which I believe may not be the case.....because resistors grounds are tied together under license plate and blinking modules are grounded under passenger seat to the factory wiring harness. So, will connect jumper wire between both grounds and see if blinking stops on right side.
    I've got one LED, in the middle of my right fender lights, that blinks a little bit...
    I jus figure it's a "spotty" connection in there, and am willing to overlook it!
    (It's not worth the effort to replace the entire marker light, over one funky little bulb...)
