Does the RT-622 have sealed wheel bearings
I'm going on a trip soon and want to insure my wheel bearings are in good conditions.
I asked my dealer if they could check and repack the wheel bearing on my RT622 trailer. He informed me that those bearings are sealed and can't be repacked. He said the hubs have to be replaced if there is a problem. Can someone shed some info on matter.
Bob
Your dealer is incorrect. The procedure is in your trailer owners manual. They can be checked and repacked.
What your dealer is correct on is that BRP does not offer new bearings as a replacement part. Must be bought as a hub assembly. I would guess the bearings are available in the aftermarket.
2018 F3 LIMITED
Interesting. ...
Of course you should check and repack them before a long trip.. Why is a good question considering that they are more than likely not an off the wall size that you could not replace them with sealed bearings. unless they cannot be removed....
2012 RS sm5
CruzrJoe had a pretty informative thread about the 622's bearings. You might want to get in touch with him about it.
The RT-622 does not have sealed bearings, your dealer is mistaken.
The New Freedom Trailer does have sealed bearings.
Cruzr Joe
This is a repost from 2 years ago. Cruzr joe
Nice day out today so i decided to repack the bearings on my 2010 RT-622 Trailer,........................ Glad I did, when you take off the dust cover it looks pretty good, lots of grease and no moisture, but decided that i was gonna get it done anyway.
Outside Bearing had plenty of grease ..................... Good
Inside Bearing had a little grease ...............Not So Good
Total Repack = No More Concerns ..................Really Good
When you check them don't rely on what you see when you pull the dust cover off ........................... Look further, it may make the difference on your next trip.
Cruzr Joe
Invalid Emails
Bearing Buddies
I put the above on my 622 as I put significant mileage on trailer.
My Motto Is:
Live my life in such a way that when my feet hit the floor in the morning...Satan shudders & says "Oh, crap, SHE'S awake!"
Red Stallion: 2016 F3t SE6 (from Pitbull PowerSports/ Springfield, MO)
White Knight: 2014 RTS SE6 and matching 622 trailer (from Pitbull
Ms Spydee: 2010 RT SE5
Bearing Buddys do not get grease to the inside Bearings! FYI Pull the wheel and pack that rear bearing by hand.
Jack
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
I just repacked our bearings on our new to us RT-622. The previous owner had them done and it had 2 kinds of grease in the hub. Glad I checked ours. The inside bearings had a considerable less grease also.
Sent from my SAMSUNG-SM-G920A using Tapatalk
2007 M109R LE - To many MODS to list. Its cheaper that way!!!
Need More Info
I bought a used 622 trailer and did not get an owners manual. Does anyone have a link for checking and repacking the wheel bearings. I would really like to check them before our trip scheduled for mid July.
Thanks, ride safe
Rich
2014 RT Limted, platinum, with matching 622 trailer.
Ultimate tall boy seat w/adjustable back rest, Corbin armrests, Spyderpops bumpskid & missing belt guard, BRP side air vents, Lamonster lidlox, cargo nets, Stebel air horn, Wrap my spyder accents......and more
Thanks, ride safe
Rich
A pdf version of the owners manual is available on BRPs website. If you can't find it let me know and I will post a link.
2018 F3 LIMITED
Found it
Got it, Thanks for the help.
SpyderLovers Sponsor
Trailer hub
I did Ann's hubs today. She was worried the bearing buddies did not grease the inner bearings; so, took them apart, wiped off old grease, packed in new, charged up the bearing buddies, put back together. FYI, plenty of grease on inner bearings. Plenty to start with, and plenty in the buddy. So, no, not sealed wheel bearings. Old school, hand full of grease, messy fun! Hey, BRP, the 70's called: they want their bearings back!!!
For 4 grand, the 622 should have sealed ceramic bearings!!!
call me if you need help. Joe
Joe Meyer
If You need to replace bearings here is a link to ones I have used.
Westernprime Trailer Hub Wheel Bearing Kits L44649 L44610 Spindle 1.063'' (1 1/16-Inch) Grease Seal 15192TB I.D. 1.500'' for 2000# EZ Lube Axles
Reason: add
2021 Sea To Sky, 2020 RTL
but our benefits don't?
If you only need to repack your bearings then pick up two seals #14848. You will need to remove the ones on the back of your hubs in order to repack the rear bearings.
Does the 2015 Freedom Trailers have sealed bearings?
www.sasspyders.com
2016 F3T
Sypderpops BumpSkid Plate
Lamonster ISP Key Cover
Lamonster F3 Bar Clamp and Power Port
Lamonster RIP floorboards and frame caps
Lamonster Chevron Highway Pegs
BajaRon Swaybar & Heim Links
F4 Custom 21" tinted windshield
BRP Cannonball Seat
BRP F3 Idler Pully
FOBO TPMS
LidLox (dual)
Garmin 660LM GPS
Cat Delete Performance Pipe
F3T Top Case
PPA Black Widow Wheels
Custom Frunk Wrap
By the look of it the Freedom trailer has a sealed double row ball bearing in each wheel. Similar in design to the front wheels of the Spyder.
2018 F3 LIMITED
YES, the freedom trailer has sealed bearings.
See Post # 5
Cruzr Joe
