Can someone post a pic of what the seals look like for the 2 lids on the 622 and a size/measurement of the seal. Just got a 622 and it didn't have the seals installed. Also if you could post a pic of where the seal runs on the lid as well. Thanks,
Shane
Sent from my SAMSUNG-SM-G920A using Tapatalk
2007 M109R LE - To many MODS to list. Its cheaper that way!!!
Ok, I think I already have them installed. The previous owner handed me a section of rubber seal but it just looks like bulk seal and said it goes on the lid. Based on the previous comments, the rubber seal that goes on the box itself is there. So I guess I'm good to go then?
A tip from Capt. Jack. After installing the new seals, spray them lightly with silicone spray every 3-4 months. This prevents the seals from sticking to the lid when closed tight for long periods of time. If this happens the rubber pulls off the mounting flange and the results are what you have.
You can purchase Silicone Spray at Home Depot or any hardware store. I use it as a lube on almost everything. It is non greasy and dirt will not cling to it.
Over and Out, Jack
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
Over and Out, Jack
Is there a particular brand I should be looking for or type?
Any Silicone brand will do. Had the same thing happen to mine thats why I started using the Silicone.
Jack
2015 BMW R1200R LC
Good seals like the ones I sell don't need any spray and they don't come apart.
JT
In the extreme heat here in the Southwest with the lids latched for long periods they will stick if dry. We have no humidity and when the rubber begins to dry it adheres to the lids.
Jack
2015 BMW R1200R LC
