click click
I guess me and Indiana Ken's 2012 RTs are talking to one another. I went to start the bike yesterday and it just clicked. Turned off the ignition the gauges went crazy and lights blinked and tried again and click. I hooked up jump box and still same thing. I hooked up battery charger and let it charged for about 45 mins. on 2 amp and still click. Is it time for a new battery or what? I at least thought it would start if i tried to jump it off but it did not. I took battery to a local auto store and it read 10.5 volts at least that's what the tech told me. And she also said it could have a dead cell. I's a 2012 RT Limited SE5, got 9500 miles on it and keep it on a battery tender when i'm not riding.
2012 Spyder RT Limited Lava Bronze (Psalm 27:1;Luke 12:4,5)
It is time for a new battery
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
It is time for a new battery.Do not get a battery that is bottle filled get a seal battery
Interesting. ...
10.5 will not due...jump starting should have worked unless the battery is blocking the the flow. Connections can also cause problems but if the charge did not help and if they load tested the battery I will go with get the recommended battery and get back out there....
2012 RS sm5
Bad battery .you can get one from any auto parts store.
4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
O'Reilly's auto parts store has a replacement battery ........................ Stock # ETX 18L that is a good replacement.
Cruzr Joe
battery
Cruzr Joe
That's why i love this forum. Thank you guys for the info. I just came from O'Reilly's today and they would have to order me one. I am going to make sure the part# is ETX 18L. I didn't go ahead an order it today, since i had it charging on 2 amp last night and thought i would give it another try, but to no avail. Off to O'Reilly's i go.
I keep my Micro Start with me in situations like that. It got me through a few dead batteries in my truck and now I keep one handy if I go on a trip on my
2015 RT Limited Black Matallic
BAJARon Sway Bar w/Billet Aluminum Heim Joint Link Set
SPYDERPOPS Bumperskid with LED's
SPYDERPOPS RT BRT Rear Lighting Kit
US LED Flag
need new battery & i too have micro start just in case. my next battery will be lithium ion
