Results 1 to 10 of 10
    Dec 2015
    South Carolina
    Default Problem with 2012 RT SE5 -
    Spyder has 12k miles. Has been running great. Had it up on a lift yesterday, putting on a a Smoothspyder belt tensioner / guard.
    Played with some wiring, but did not connect anything. It has a low gas tank with about one bar showing.
    When I took it down off the lift and started it up, the screen said check engine. Engine idled at 1700 bounching up to 2200 RPM instead of the steady 1400 RPM it used to idle at. No power when reving.
    Turned engine off. Turned back on and it ran fine for about 1 hr. Stopped for lunch, It started up just fine.
    Today I go out, and check engine light is back, and will not change after several tries over about 1 hour.
    Anybody got any Ideas.?
    Nov 2012
    North Las Vegas, NV
    Retrieve the codes, that will help. While it is running and showing Check Engine push the SET, MODE, and TURN SIGNAL cancel buttons at the same time. Active codes will show on the dash screen. Let us know what they are.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    washington state
    It maybe a gremlin and If she went back to normal why bother.
    2012 Spyder RT SE5 Brake pedal mod
    Jun 2010
    Las Vegas
    Quote Originally Posted by jerpinoy View Post
    if it didn't go back to check engine he wouldn't be able to check for codes anyway.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    Played with some wiring, hmm... SPUT !
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    Nov 2012
    North Las Vegas, NV
    He said the check engine light came back on. So I was hoping to get the code.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Active Member philblumenfeld's Avatar
    Usa
    Check for loose battery cables.
    Default Curious. ....
    Did you run her in gear with the wheels off the ground while installing the tensioner..?? I know RT's don't like that.. also check fluid levels and make sure the wires you moved did not come loose at the plug...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Dec 2015
    South Carolina
    Default Thanks for the comments
    No - while playing with some wiring, didn,t touch the battery.
    Didn't run the bike while working on the belt tensionner, or when it was on the lift.
    Will check codes if it happens again.
    Stuff like this eats at me. Got up in the middle of the night and started the bike. Started like a champ.
    Gremlins ... maybe ?
    I watched a video on lifting bike. Placed the lift under front peg area on frame. When off the ground (I always use jack stands), but before I position the jack stands, the bike is balancing, and not rock steady - like it is balancing on one point, rather than the two rails on the ATV jack. Is this common, or don.t I have the jack forward enough?
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by Indiana Ken View Post
    If you have a smart phone you can get the "spyder codes" app and all will be revealed.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
