Results 1 to 6 of 6
Thread: Zumo 590
    Active Member GRIPMAN's Avatar
    Greenbank, WA
    Default Zumo 590
    Using the Garmin 590 on a 2016 RT but cannot transmit in blue tooth mode without using the "PTT" button, is this normal or is the unit wired wrong?. Thanks for information on this problem from members or BRP
    Joseph
    Active Member nakerr's Avatar
    Dec 2013
    Fort Saskatchewan, AB Canada
    Quote Originally Posted by GRIPMAN View Post
    Joseph
    I am a little confused about your "transmit" comment. How/why/what does a GPS unit transmit?
    Norm
    ...Not All Who Wander Are Lost" - Bilbo Baggins
    2015 RT-S SE6 Special Series
    Greenbank, WA
    Default Garmin 590
    Quote Originally Posted by nakerr View Post
    Cell phone blue tooth connection is through the 590 GPS and my hook-up will not permit talking to caller.
    Joseph
    Jul 2015
    Dorr, michigan
    What bluetooth headset are you using?
    I have the Garmin 590 and the Sena 20s headsets, it all works great.
    2020 RT Limited , Petrol Blue
    Danbury Connecticut
    Joseph
    I'm assuming you have a wired headset ?
    You need a special part in order to connect to the GPS. It's the cell phone interface, I don't remember the part number.
    If you have a bluetooth headset, just pair your phone to your headset directly.
    Either that, or you need to pair your phone to the GPS and then pair your headset to the GPS.
    If you could add more information as to what equipment you have installed, it would go a long way to allowing us to help you.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Very Active Member stevedfive's Avatar
    Aug 2010
    Riverside, California
    If you have a wired headset system, then the part number for the cellphone interface cable is #219400390. Feel free to PM me and I will send you my number if you have questions about the BRP wired communication system.
    2014 Timeless Black RTS/SE - BRP CB/Comm System; BRP Zumo 660 GPS System; BRP Cellphone Interface; BRP ST-1 Helmets w/BRP Headsets; BRP XM Radio; BRP Tri-Axis Handlebars; BRP Adj Wind Deflectors; BRP Adj Vent Windshield; BRP Comfort Seat & Utopia Backrest; Corbin Armrests; HMT Brake Light; TricLED 3/4 Brake & Running Lights; TricLED Fender Lights & Rr Cargo Lights; CD Fender TIPS Kit; Bump Skid; Scorpio i900 Alarm; Touratech GPS Locking Mount; NBV Highway Mounts; BBP Brake Pedal, Stebel horn.
