Results 1 to 21 of 21
    Active Member rworell's Avatar
    Jul 2013
    Southern Maine
    Default Rough ride on the back of RT
    So unfortunately we live in an area where the roads could be better "lol". But while my wife and I are out, occasionally we hit some rough patches of road and my wife says its not to pleasant on the back of my 2011 RT. I've adjusted the shocks both to (Hard & Soft). Not much difference and so I was the passenger last night. Holy cow. I have to agree its a rough ride on the back. Any suggestions from my Spyder guru's?
    Thanks for your opinions all... Your Rock
    Rich
    Active Member WARWAGON's Avatar
    Feb 2013
    Hamilton, Ohio
    Quote Originally Posted by rworell View Post
    Rich
    Make sure you do have air in ACS. My 12 had a leak that on board compressor could not keep up with. Manual check under seat of o see if it's holding air.
    Steel Black Metallic 2015 RTS-SE6 Limited ; FBB Highway Brackets/ gripper pegs. Gremlin bell. Bajaron sway bar, Elka stage 2 front shocks. Bumps kid with led lights, Ultimate seat tall boy seat. Trailer hitch. Freedom trailer.
    Very Active Member Dan McNally's Avatar
    Jun 2013
    You could do what many in Maryland Spyder Web have done - get another Spyder for your wife! It will dramatically improve her ryde!
    "Topper" is my Pearl White 2013 RT-LTD
    Professional Retiree - liked it so much when I retired from the USAF, that I started another career so I could do it again!
    Happy to be a member of the Maryland Spyder Web - find us at
    http://www.meetup.com/MarylandSpyderWeb/
    Rich,
    Exactly which model of RT are you riding?
    (There's nothing in your profile or signature about it...)
    If you have a Base model: put some air in the rear shock.
    If you've got an RT-S or Limited: have your dealer check the ACS for proper operation.
    Beyond this: it'd be time for a rear Elka!
    Good Luck!
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    kinda on the subject. my rts has what looks like a shrader valve under the seat.
    is it just for looks or to pump up beach balls and air mattresses?--irv
    2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
    and some little stuff. setback utopia backrest, baja ron
    sway bar, oem adj. air deflectors, marlin gps compass,
    lamonster fbb foot pegs[modified brackets], lamonts
    vibration damper, rock guard, and side case stiffener kit,
    . brp comfort seat. , fomozas and
    altimax, magic mirror mts, and wide mirrors.
    [joyce & irvin toms]
    Sine you've got an RT-S (With the automatic ride height control); that valve is a little bit "extraneous"... You shouldn't ever have to touch it.
    Unless your sense of curiosity overpowers you, and forces you to put a pressure gauge on it...
    Jul 2013
    Southern Maine
    Its a 2011 RT Limited....
    Rich,
    Good Luck!
    Since it's a Limited; you might be having trouble with the ACS...
    It's probably time to let the dealer take a look at it.
    Good Luck!
    Jul 2010
    Las Vegas, NV
    Default Air shock
    Quote Originally Posted by Joyce47 View Post
    use it to put air in the rear shock.
    Joe Meyer
    Irv is on an RT-S. He can add air via the ACS.
    If it turns out to not be the air in the shock, try a sheepskin/gel pad or an Air Hawk cushion. Both will give some relief to the bottom.
    Sep 2013
    whitman mass.
    I had that problem on my 2012rts.it was a bad shock. No rebound. Air system was ok
    There have been more than a couple of reports of shocks from that era RT; failing...
    Jul 2013
    Southern Maine
    Default Is there a recall??
    Wondering if a recall notice would be out on possible bad rear shocks? and if so would BRP cover it?
    Invalid Emails
    Mar 2012
    Gore,Quebec,Canada
    Mine was a bad shock. Dealer replaced under warranty about 2 years ago.
    2012 RT , stock Lava Bronze
    There was never any TSB, OR recall issued, for this area of concern...
    .Be ....EXTREMELY ...careful about putting air in the rear air bag......it's very small and will rupture easily if overfilled......BRP says only fill it with a HAND PUMP ......IMHO if you have a 12volt compact type compressor that will work........Mike
    Small steps...
    Sep 2012
    Stetson, Maine
    I use a compressor, but I set the outgoing to only 50lbs. Be warned that checking at the Shrader valve more than a few times will cause your pressure to drop quickly. If riding double you should have at least 50 to 60lbs.
    Very Active Member SteveLaoyster's Avatar
    Nov 2015
    Myerstown, Pennsylvania
    Default Air....
    I was thinking along the line of a air donut. The kind you use when you've got a sore bottom & don't want it to get any worse.
    2016 RT-S , stock not yet Pearl White
    Jul 2013
    Southern Maine
    Default Adding air if it's an RT Limited?
    Can I add air if mine has the front toggle switch to go from high to low? I Just want to be clear on that before I check air pressure and possibly if needed, add air with my hand held air pump.
    Rich
    2011 Black Magic RT Limited
    Sep 2012
    Stetson, Maine
    Yes you can add air manually. Bruce
