Gremlins in fuel gauge
Fuel gauge reads full after fillup and starting. then while riding, the gauge reads full, then empty with low fuel light.. then 5 min later, full again, then later, empty with low fuel light.
no consistency staying broken or ok.
Not hitting chuckholes/train tracks etc that might make fuel tank float(I'm ignorant..thinking of car gas tank) stick
any ideas?
Former Navy LT, Retired Chemical Dependency Therapist, Retired Widower, "Do, or do not, there is no try"... Jedi Master Yoda.
Proud member of AA, PGR, and a Navy Shellback!
Well....
sounds like a loose connection or a faulty sending unit. Did not see what model you are talking about but if it is the RT you can disconnect the temp and fuel gauge and get the digital read out on the screen. if it is an analog guage it could be the guage. If it is the digital guage more likely the sending unit.
2012 RS sm5
any ideas?
Did you find a fix?..
Originally Posted by akspyderman
Sounds electrical. Chupaca has some good ideas.
it's a 2008 GS semiauto. Took to dealer, they replaced the instrument pod. gas gauge and turn signal work great now.
Glad to hear that it's been fixed...
There's nothing more entertaining, than peering into your fuel filler spout while using a cigarette lighter for illumination...
I need some entertainment. Don't have a lighter, but think that one of those candle lighter torchy thingees will work. Will let you know what I find.
K A B O O M
Large explosion rocks Alaska, news at ten.
