Results 1 to 8 of 8
    Active Member kbwitt's Avatar
    Jun 2015
    AZ
    Default strange sound on 2014 rt
    Hard to explain sound , like something opening and closing. It started after a
    Headlight bulb replacement. Good that have something to do with it lije something not rehooked up?
    Thanks for your responds. It happens when first starting or at stop light.
    Kenn
    Jul 2011
    Mitchell, Ontario, Canada
    Switch between high and low beam headlights a few times. Is that the sound? If so it's the headlight shutters.
    Was that it?
    Was that it?
    x 2
    Oct 2014
    Fort Mill, SC
    My money is on the shutters also.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Jun 2015
    AZ
    Default no not the light shutters
    It sounds like clicking
    It's not "valve-tap"; is it?
    Jun 2015
    AZ
    Not sure how the bulb replacement could make the sound, but I suppose it is possible.
    The two things that lead me away from the bulbs are the starting and stopping.
    I may be way wrong, but are you sure it is not something to do with the rear suspension. I know you posted it as a 2014 RT, which should not have air ride on the back, but if it is an RTS or RT Limited, you get what could be termed as odd clicks and buzzes when stating out or stopping.
    Again, likely wrong, but wanted to share that.
    Editing on account of a quick check of your profile indicated it is an RTS, so maybe there is an unrelated leak in your rear suspension air ride, or possibly you made a setting change accidentally and the system is trying to keep up.
    Thanks for info you are correct its a 2014 RT S i did not know there was a difference between it and rt. I know rt limited has extras. Mine does have a switch to adjust suspension.
    Kenn
