LED Bulb Tail/Brake Light
I have a 2015 F3S and would like to install a LED bulb for rear brake/turn/running light. I already have a LED "bar" across the back of the tail section, but want to have more visibility than I get from the OEM bulb in the stock housing. Any suggestions is greatly appreciated.
Got this from Amazon. SFSG :
RV Lighting (67-W7) Eco-Led Cold White Bulb https://www.amazon.com/dp/B00IL0ZQLE..._2b3rxbT7AA9C9
If you use the led plate light that I mentioned, the replacement lens from Custom Dynamics works well with it.( Sorry, I just realized you were asking about the brake light!)
Sent from my DROID RAZR HD using Tapatalk
LED Brake, Rin, Turn
I bought mine from Amazon. Type in JDM Astar n the search box. Super bright!!
2020 F3 Ltd
Spyderpops Bumpskid
LED Bulb
JKMSPYDER, thanks for your response. Can you tell me what size/model of the JDM Astar LED bulb will fit in the F3S?
