Still flopping around in the Spyder trailing saga. My wife is retiring soon, and I want to trailer our 2014 STS around.
Tried hard to get it up my 6 x12 enclosed utility trailer. Couldn't figure that out. Just got back from a Uhaul and trailer place. They said... no way... they can't figure that out either. They said buy one of those trailers that drops down. Okay,$ 6,000 for a little open trailer we are going to use for a few years. No way. I want an enclosed trailer for that kind of money. I want an Engineer genius to tell me how to get my STS into my enclosed 6 x 12 utility trailer. : )
How could you not..?? well not being the trailering type I would have to see the configuration of the trailer. Even if the front wheels don't clear the wheel wells if you back it in you should have the room.
Gene and Ilana De Laney Mt. Helix, California
2012 RS sm5
It's actually pretty easy...
How long is the tailgate/ramp on your trailer?
(I assume that's what it has.)
What is the load height of the trailer?
What you'll need to do, is cut two pieces of 2x8 lumber. Make two of them about five feet long.
Place these ramps against the tailgate of your trailer, and let them extend rearward from the tailgate. You'll be riding your Spyder up onto these (Make sure that the front wheels land on them...), and then onto the tailgate.
This should be able to lessen the approach angle, and allow you to load the bike without dragging it's nose on the tailgate.
a lot of people have come up with differant ways to do it, longer ramps to cut the incline, backing truck onto blocks to bring nose of trailer up but without knowing exactly what you have and why you cant load it there is not much we can do
I rented a 6' x 12' trailer when I went from Michigan to Kentucky to pick up my 2014RT in March it fit with plenty of room. The only problem was the cables on the ramp was in the way just moved them a bit and all was fine. Clean bike when I got home.
I don't haul my Spyder often enough to justify spending a lot of money on a trailer either. I use a 6'x8' utility trailer with a few little modifications. If your ramp is to steep, this is how I made it work for me.
Joe
Any suggestions?
Here is mine in a 6 x 12 Stealth All Aluminum Trailer, Only $3700.0
Frank
To get my GS home from CT..Fit fine, and just brought some extra 2x12's to help load her up. There are plenty solutions to your delemma. Asking for assistance was the first step. Good luck and keep us posted!
rented a Uhaul 6x12 trailer, I used 2- 4x4 blocks of wood and car ramps. The blocks of wood held the tail gate up to the height of the ramps, lined up drove on to the car ramps then on to tail gate moved 1 of the ramps under rear tire and drove on.
Improvise, Adapt, Overcome, Semper Fi
2020 RT
Limited heated seats
removable back rest & rack
XK Glow light
Paint with light painted panels
(Gone but not forgotten ) 2009 RS SE5
A few easy things you can do are: position the trailer in a place where the tires are in a dip to reduce the incline of the ramp (the transition from street to driveway works well). Another thing is to, using the jack of the trailer with the trailer hooked up, jack it up as high as it will go (you'll be picking up your vehicle a bit too). This will also reduce that ramp angle. Another thing is to lay a piece of lumber under the very end of the ramp when it's down, again reducing he angle. Another, if you're in town and have curb/gutter, park the trailer in the street and drop the ramp onto the curb and ride the bike through the lawn onto the ramp. All of the above can easily be done for free, and if you can combine a couple of them together, it'll be easy. Anything you can do to reduce the ramp angle is the key. Those fancy dropping trailers are sexy, but no way worth the cost in my opinion. It should wash your bike at your destination for those prices
If you are going to use the trailer for a limited time and a limit number of times, rent a U-Haul. You don't have to worry about storing it or maintaining it. It will be cheaper.
2011 RTS (Sold to a very nice lady)
1998 Honda Valkyrie
2006 Mustang GT. Varooooom!
US Navy Veteran
SC Law Enforcement Boat Captain
CNC Machine Service Technician
President: Rolling Thunder SC1
Member: Disabled American Veterans, Rock Hill, SC
Member: American Legion
Experience is recognizing the same mistake every time you make it!
Enclosed trailers are a huge air drag so mpg drops bad hard on traney, and a pitch in heavy side winds. I find open trailers a better way. Thats my4 cents
Kenn
I paid $5500 for an all aluminum 7X12 enclosed trailer. With brakes. V-nose, drop down front. Rear door drops down, and has a transition flap. No problems getting in or out. Tom
Baloo is my name. Spyders are my game. Well, it's a doo-bah-dee-doo, yes, it's a doo-bah-dee-doo, I mean a doo-bee, doo-bee, doo-bee, doo-bee, doo-bee-dee-doo. And, well, now. Ha ha! What have we here?
Hi Bob,
No way. I have no ramp on my trailer and the height is 17 inches. I tried that with 6ft ramps. No way. The middle of the bike gets jammed up. The rear wheel needs a lift. I may try to order 10ft arched ramp system that I saw online. Thanks for the write back.
Kenn
Hey Kenn,
I know a lot about trailering from many years of camping. You know a lot too.... because your response makes a lot of sense. But spend 6 or 7 k for an open trailer??? That ain't happening.
But... let's say my wife and I want to go hang out in Fla. for a few weeks. I am thinking my bike would be better safe and protected when we are out somewhere... if it is in an enclosed trailer. What do you do to protect your bike when u travel?
Hi Tom,
How long is the ramp and transition flap? Would like to know make if it was a new purchase. Is that with tax and shipping?
Thanks friend,
That is a great idea. However, my problem is getting the bike on a trailer. Does U-Haul have a trailer with a ramp that would accommodate a 2014 Spyder StS?
They had a two-axle trailer, I don't know how long, but longer than the RT was. They unhooked the trailer from the hitch, tilted the trailer, and drove up the trailer. The trailer did have a short ramp that made the pitch too steep for the RT. He used tire blocks to keep the trailer from rolling once the trailer flattened out. I did not see him unload the RT, but he said it works good, just like loading it. I told him he was a braver man than I was, but for him it worked.
Is it Friday yet? ... Oh yeah, I forgot. I'm retired
Past bikes
2010 RS - Sold
2012 RT - Sold
2014 RT - Testing completed
2016 F3-T Audio package - Sold
Joe
New, $5500 plus tax. Transition flap is 12" I think. Rear door 6' long? I 'm guessing here. I can measure tomorrow. Tom
I have made many winter trips from northern Ohio to Florida Via I-75 and have always encountered heavy salting conditions at least part of the way. I consider open trailering over wet salted roads the same as dipping them in sea water, at this point most insurance companys render a vehicle a total loss. Covering them with a tarp or full cover can make the situation even worse. In my humble opinion the only solution is an enclosed trailer. Now, I have never transversed I-95 in the winter so I do not know the salting conditions one may encounter. Water and dirt is one thing, salt and the additives to it are another.
Good luck in finding a solution.
By the way, the wife and I are trying out the new toy hauler rv this weekend. A Vengeance 29V
I will be putting my 6 x 12 Stealth all aluminum trailer up for sale later this summer.
doesn't this configuration put too much weight in your hitch?
