Page 1 of 3 123 LastLast
Results 1 to 25 of 67
    Bryant, Arkansas
    Default Things you might not know, please add to this list. (RT Series)
    On a RT Series Spyder
    The Right side Saddlebag is larger than the Left side.
    If you don't use the parking brake when you turn the Spyder off, the beeper will quit after 20 seconds.
    Your Tires are Directional and should not be swapped side to side.
    Your battery charger/tender should be compatible with an AGM battery.
    If you use your car Battery to jump start your spyder, leave the car turned off and remove the jumper cables from your spyder as soon as it starts.
    If you want your Fuel & Temp gauge to be digital on your dash just unplug both your analog temp and gas gauge and the digital ones will appear on your display.
    A good rule of thumb for tire pressure is 18 (+ or - 2) for the front (be sure both are as close as possible for maximum ride stability) and 29 (+ or - 1) for the rear.
    Be sure that your Spyder is warmed up good before checking your oil, do not overfill your oil.
    Be sure that the brake reservoir caps (located under the seat) are on solidly and that the slightly raised area is pointed toward the back of your spyder or it could leak brake fluid.
    DO NOT use a power washer to clean your spyder especially around the dash area.
    If you can think of more good suggestions please post them on this thread.
    If you allow your spyder to warm up for two or three minutes when you first start it for the day, it will run smoother with less "CLUNK".
    Check your tire thread and replace if worn or there are any visible cracks or tire rot marks.
    Cruzr Joe
    washington state
    Thanks a millions CJ
    2012 Spyder RT SE5 Brake pedal mod
    Very Active Member garb55's Avatar
    Coolidge Arizona
    I don't know what I don't know
    So how can I add it to the list if I don't know it
    Now 2014 RT Limited Cognac
    Was 2008 GS SM5
    Don Garbarino
    Cup Holder
    GPS locking holder
    Mud flap
    Modified KNOTT grill
    Phone holder and charger
    Trailer hitch
    Dual air horn
    Auxiliary fuse box with relays
    Heated clothing controller
    volt/oil pressure gauge
    Sequential signals in mirror
    Tri Axis Handle bars
    Baja Ron anti sway bar/heim links
    shorty antenna
    And many more
    Bryant, Arkansas
    Quote Originally Posted by garb55 View Post
    I DON'T KNOW.
    Anonymous
    Active Member Ex Winger's Avatar
    Apr 2015
    Brockville ONT
    Didn,t know about the digital gauge gauge Thank,s
    Bill
    2018 RT Anniversary , Brake pedal extended
    Mar 2016
    Indiana
    Cruzr Joe
    I'm going to try this with my 08 GS SE5. That "clunk" has always annoyed me and worried me.
    I won't get to try it for a few days, as I have several new farkles to install, but I will report back.
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    should be made a sticky[sp].--thank you-irv
    2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
    and some little stuff. setback utopia backrest, baja ron
    sway bar, oem adj. air deflectors, marlin gps compass,
    lamonster fbb foot pegs[modified brackets], lamonts
    vibration damper, rock guard, and side case stiffener kit,
    . brp comfort seat. , fomozas and
    altimax, magic mirror mts, and wide mirrors.
    [joyce & irvin toms]
    Very Active Member Deer Slayer's Avatar
    Mar 2015
    Advance, NC
    Default Warm up and Safety.
    Great post! I always warm up my Spydee as I dress in my gear and brain bucket.
    In the safety mode, use your flash to pass on an 18 wheeler then pass smartly. In the Summer you do not want to be beside a big rig when the tyre blowes! I did the flash to pass and got many waves from drivers on my 3400 mile Texas trip. Ryde on my friends.
    If I can't fix it, I will fix it so no one can fix it. Sypder Loco!
    The newer RT models have a power port in the top trunk, that can either be hot all of the time, or powered-on when the ignition switch in on...
    In the right-Hand fusebox:
    If there's a fuse in position #6: the power port is going to be a keyed source of power.
    If it's in position #7: it's hot all of the time.
    You can use this to your advantage, by having accessories that are plugged into it; be powered down at shut-off, or you can plug a Battery Tender into it, when it's hot all of the time.
    Jul 2014
    Mint Hill, NC
    Regarding Bob's post about the fuses. You must go by the owner's manual numbering of the fuse slots and not the black embossed numbers on the fuse panels. The numbers on the panels are opposite the numbers assigned in the owner's manual.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Registered Users nightshift357's Avatar
    Jul 2015
    north Carolina
    Are fuse # 6 or 7 a 40 amp ?? (R) side.
    Sent from my SM-G925V using Tapatalk
    Aug 2013
    Northern California
    Default Well
    Of course you can do wheelies.....but only in reverse!
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by nightshift357 View Post
    From your point of view looking in the front trunk. The Spyders right fuse box is on your left.
    2018 F3 LIMITED
    5 amp.
    Quote Originally Posted by 2 Cruysyn View Post
    Aside from loosing the ability to channel water out of the way why else would you NOT want to run directional tires in the reverse direction?
    "Aside from loosing the ability to channel water out of the way... "
    What more reason do you need?
    Jun 2015
    Ritzville, Wa
    Default Good point
    "From your point of view looking in the front trunk. The Spyders right fuse box is on your left."
    A good point to remember
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Bryant, Arkansas
    Quote Originally Posted by gkamer View Post
    I always use the "sitting on the bike" as my reference for right or left.
    Cruzr Joe
    Bryant, Arkansas
    Nov 2013
    Oro Valley Arizona
    Thanks for the information Uncle Joe! Useful indeed.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Active Member Commander's Avatar
    Jun 2014
    Southern New Jersey
    Great Info and Great people on this Forum. Thank you....
    2015 RT Limited Black Matallic
    BAJARon Sway Bar w/Billet Aluminum Heim Joint Link Set
    SPYDERPOPS Bumperskid with LED's
    SPYDERPOPS RT BRT Rear Lighting Kit
    US LED Flag
    Quote Originally Posted by jaherbst View Post
    Jack
    Default Yikes...!!
    Too much to deal with.....RS lover here..
    ​2012 RS sm5
    Pragmatic Member Pampurrs's Avatar
    Mar 2015
    San Tan Valley, AZ
    Good stuff Joe
    Here's one I discovered by chance:
    When you depress the "Set" button while riding, the display toggles between Trip A and Trip B.
    Pam
    • 2015 RT-S Special Series / Red & Black
    • Baja Ron Sway Bar
    • Utopia Backrest
    • F4 Customs tall and wide vented windshield
    • Stebel Super Loud Air Horn
    • Baker Built Air Wings
    • LaMonster Highway Pegs
    • SpyderPops Exhaust Block Off Plate
    • SpyderPops KOTT Grill
    • SpyderPops Belt Guard
    • Cat Bypass
    • Laser Alignment by Squared Away
    • TricLED Fender Lights
    • General Altimax RT43 rear tire
    • Dual flag holder
    • Mud Flap
    • A$$hole seeking missile system
    Jun 2010
    Las Vegas
    Some people's idea of "warmed up good" may not be sufficient for getting an accurate oil reading. Follow the directions in the Owners Manual for checking the oil. And be extra vigilant on being sure that you have run the engine the recommended amount of time or you will not be getting a good reading.
    Another add to your list would be to read your Owners Manual, there is a wealth of information there. If you don't have one you can read it online at www.can-am.brp.com
    On the 14 and newer RT you don't have to wait for the start up menu if you have turned the engine off for less than 5 minutes. You can start it while the screen is going through its paces. So if you just fueled up you can turn the key on and hit the starter button without waiting.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    "On the 14 and newer RT you don't have to wait for the start up menu if you have turned the engine off for less than 5 minutes. You can start it while the screen is going through its paces. So if you just fueled up you can turn the key on and hit the starter button without waiting."
    "When you depress the "Set" button while riding, the display toggles between Trip A and Trip B."
    Ann & Pam,
    I hadn't heard of these; Thanks!
