Can we use regular battery charger?
Can we put our 2015 RT SE6 on a regular battery charger? We have tried a tender, but it hasn't charged back up. It discharged when my husband listened to the radio while working on it. I need to ryde it Friday morning and it's not looking good right now.
Sent from my SAMSUNG-SM-G890A using Tapatalk
I am not worried about him listening to the radio. I have to get it charged so I can start it. I can't even put the parking brake on. There's no dealer around here to help.
Yes you can use a battery charger. You can jump it off with a car. But do not leave the car running when you jump it off
So jump it with the car off?
Yes, dont even have the key in the car ignition. Just hook up the car to the Spyder. The procedure is also in the owners manual with a step by step.
Sent from my SAMSUNG-SM-G920A using Tapatalk
2007 M109R LE - To many MODS to list. Its cheaper that way!!!
I mustn't have looked in the right place. Thanks for your help.
Charging Battery
Sometimes what you have to do is "excite" the bike battery with a regular charger (hour or two) then put the tender on it. Tender is just that, maintains a charged battery and keeps it at a certain level.
And there you have it...
Should be running by now. .. or soon enough so you can ryde Friday. ..
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
Ozzie Ozzie Ozzie
SpyderLovers Sponsor
The Spyder comes with an AGM Battery (Absorbed Glass Mat). You really need to use a battery charger that is specifically designed to charge an AGM battery.
Each battery type requires it's own charging method to work properly. Neither a standard Lead-Acid or Gel charger is appropriate for an AGM battery. These other charging methods will probably damage your AGM battery over time. Using the wrong charger may be why people have trouble and early failure of their Spyder batteries.
This goes for tenders as well. If it does not say 'AGM' on the charger/tender or have an AGM setting. It's not the correct charger for your AGM battery.
I toasted my battery using a car battery charger that was only 10amps. Use the car or the charger to get it started then disconnect and let the bike charge the battery. Yes, use a tender to keep it charged between rides.
One of the hardest decisions you'll ever face in life is choosing whether to walk away or try harder.
Battery Tender and Battery Tender Jr. are two chargers/tenders that are approved for AGM batteries. I am sure that there are plenty others.
Cruzr Joe
OR--- if the charger has a 2-Amp Trickle option switch, use only the TRICKLE CHARGE setting on a motorcycle battery.
NEW - 2015 RT Limited SE6 Intense Red Pearl - 07/21/15
Retained the old mirrors with TricLed Signals
General Altimax RT43 rear tire (at...17,000 miles) Ran for 36,500 miles
Michelin Defender.......rear tire (at...53,500 miles) Ran for 60,700 miles
Riken Raptor HR.........rear tire (at 114,200 miles)
Vredestein Quatrac 5 front tires (at 70,500 miles, first new fronts!)
Gear Brake Decelerometer Module
OLD - 2012 RT Limited SE5 Pearl White - 01/31/13 - Traded in at 32,600 miles.
BajaRon Anti-sway Bar
Kumho ECSTA AST rear tire (at 14,200 miles)
TricLed Turn Signals in Mirrors
Anti gravity battery chargers are a good thing to have on hand and give can give you a good piece of mind on a trip
2015 RT Limited Black Matallic
BAJARon Sway Bar w/Billet Aluminum Heim Joint Link Set
SPYDERPOPS Bumperskid with LED's
SPYDERPOPS RT BRT Rear Lighting Kit
US LED Flag
The battery tender plus is a charger as well as a tender that might also be a good idea.
US LED Flag
Update: We found out that the battery tender had a blown fuse. Put the battery charger on while watching it carefully and finally got the bike started. All is well. Thanks for the advice!
