2008 GS SE5 clutch slippage
Any thoughts or ideas besides a bad clutch why it would be slipping with less than 8k on it.
Any suggestions appreciated Thanks.
It could be low oil, or the wrong type of oil. Also what RPM range do you ride in? The engine and clutch is designed for hi RPM'S.
Wrong oil used.
Prolonged driving in higher gears at low rpm, 3200 or less has overheated the clutch.
2018 F3 LIMITED
Agree...
Also if you are running under 4,000 rpm's for long periods of time you may well have worn the clutch out on the se5 models. Those clutches need to fully engage while ryding and that is about 4,000 rpm. This is a centrifical clutch the new models have a hydraulic clutch and operate at lower rpms...
2012 RS sm5
Lockup stall speed is 3200 rpm not 4000.
2018 F3 LIMITED
Thanks, could not remember exactly thought it was 3,400 must have picked up on the four...
Sent from my SM-T560NU using Tapatalk
2012 RS sm5
SpyderLovers Sponsor
That's partly true. It's 3200 +/- 200. So some folks take it to 3400 for safety. But 4000 and above in 3rd or higher just makes for better drivability SE or SM.
2018 F3 LIMITED
Once I'm out of first gear. I keep mine above 4000 RPM'S as much as possible. The do & do not's recommends keeping it over 4300.
Thanks folks for all the input as far as oil I don't worry about that except for the level it is dealer changed. Also that was the first ride of the year it was fine when parked in Oct. 15 Total miles for ride 100 and it was about 10 miles from home when it got squirrrely Iwill recheck oil level and post more Thanks again for input.
You have to warm the oil up if not the clutch will chatter that happens on my 2 friends 998 cc bikes
