Results 1 to 13 of 13
Thread: Hitch Removal
    Invalid Emails
    Jul 2014
    Rotonda West,FL
    Default Hitch Removal
    I did not get the manual with my BRP hitch. Can someone tell how to take it off the easy way. or send me a pdf copy of the manual.
    Thanks
    Jun 2010
    Las Vegas
    There is a cotter pin that you need to remove first on the right side then you need 2 - 19mm wrenches to loosen the bolts then you pull out the axle. When the axle is removed you can remove the hitch by either pulling it or hitting it with a rubber mallet.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Sep 2014
    USA
    Quote Originally Posted by SpyderAnn01 View Post
    Invalid Emails
    Sep 2015
    Elyria, OH
    And having just installed one, also don't forget to the watch the wiring harnesses and the brake lines.
    Skip H
    ELyria, OH
    Default HITCH NON-REMOVAL
    Why not just take off the rear HOOP and leave the side plates ON ?????.....Mike
    Very Active Member pitzerwm's Avatar
    Nov 2014
    TriCities, WA
    Can't get a tool in there to take it loose.
    One of the hardest decisions you'll ever face in life is choosing whether to walk away or try harder.
    Jul 2010
    Las Vegas, NV
    Default Hmmmm
    After 40 or 50 of them, Ann knows what she is talking about. Good tip on the wires and lines! Be careful. Takes 5 minutes to remove. Have a big mallet!
    Joe Meyer
    Nov 2015
    Winchester, CA
    That's what I do. Life is already complicated. Don't over-think it.
    Nov 2019
    Kansas
    But you actually need to remove the back axle on the spyder to remove the full hitch?
    Mar 2013
    Quote Originally Posted by acdcking12 View Post
    No - the hitch has it's own axle (really just a long bolt)that goes through the Spyders axle. You do not touch the Spyder's axle.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Very Active Member Lin's Avatar
    Apr 2013
    Somersworth, NH
    Don't forget to install a new cotter pin in the castle nut after you remove the hitch.
    2016 RT-S Special Series
    2016 RT-S Special , 2 tone black
    Mar 2013
    Quote Originally Posted by Lin View Post
    If it has one. Both of our F3's do not have castle nuts on the axle. At 166 foot pounds of torque I am not worried about them coming loose.
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    2020 RT Limited , Marsala Red
