Results 1 to 8 of 8
    Mar 2016
    Reno NV / Sparks
    Default Am I the only one ?
    This is such a dumb thing to me but .... yesterday I finally got around to mounting my license plate and frame . The space between the rear tire and the fender is VERY tight , now my arms are not that fat but holding the nut to fit the screw was not very easy Even jacked up the rear wheel , never in my 70 years have I had such a problem with the most simple thing you could do on any bike so my hats off to the engineer , Hope I am the only one to have had this experience Otherwise great ride
    Registered Users pdxsenior's Avatar
    Apr 2015
    Tualatin, OR.
    Nope, you're not!
    2015 F3-S owner
    Very Active Member vondalyn's Avatar
    Jun 2012
    Longmont, CO
    Default bolts?
    Wow! Am I the only one who used the same screws that either a) came with the spyder, or b) that my dealership used to attach the temp plate? They aren't bolts and they don't go all the way through to the wheel side of the fender. I used plastic safe lock-tite to help keep them in place, but they were fairly long so I don't think there will be an issue.
    We now have His and Hers Spyders!
    Current Spyder: White 2015 F3-S SE6
    His Spyder: White 2015 F3 SE6
    Previous Spyder: 2012 RT Limited SE5 -- 30,300 miles
    Previous rides: Kawasaki & Honda
    2015 F3 , Pearl White
    MOgang Member Yazz's Avatar
    Nov 2009
    Cypress, Texas
    Zip-ties are your friend. They won't rattle off...
    Joy
    Very Happy Ryder...
    '09 Phantom and a '15 F3-S
    If you don't slow down, they can't catch you..
    ​If you don't give up, they can't win.
    What a long strange journey its been.
    Default True...
    Quote Originally Posted by Yazz View Post
    I have fixed many a loose plate with zip ties...It's an out on the road fix but will last forever...
    ​2012 RS sm5
    Mar 2016
    Reno NV / Sparks
    Quote Originally Posted by vondalyn View Post
    The dealer plate was on there with wingnuts and when I unscrewed the reflector screws the wingnuts just dropped to the floor , I thought there must have a set screw in there , the hole in the fender does go all the way through and you need to get a nut behind the hole to start a screw ....but between the rear tire and the edge of the fender so I will never again change that frame .will send a pic soon
    Bossier LoUiSiAna
    Quote Originally Posted by pdxsenior View Post
    Nope, you're not!
    2015 F3-S owner
    X2: The question id like to add to this is ...."did everyone only get room for top two bolts?" Yes works for most plates but they have 4holes for a reason! & my first plate frame broke off from lack of 4bolt support So i rednecked & added adapter to allow all 4 Then got a trailer hitch that apparently requires relocation & whole new plate bracket, now i am without license plate frame again, & or have the room to mount it cuz the plate light is too close & it matches my themefyi sturdy metal frame. Ill find a way just not happy with the standard "as less as we can get away with"
    Ride on &be SAFE
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Mar 2016
    Reno NV / Sparks
    X2: The question id like to add to this is ...."did everyone only get room for top two bolts?" Yes works for most plates but they have 4holes for a reason! & my first plate frame broke off from lack of 4bolt support So i rednecked & added adapter to allow all 4 Then got a trailer hitch that apparently requires relocation & whole new plate bracket, now i am without license plate frame again, & or have the room to mount it cuz the plate light is too close & it matches my themefyi rdy metal frame. Ill find a way just not happy with the standard "as less as we can get away with"
    Ride on &be SAFE
    woThere are only two top holes in thr F 3 T FENDER only reachable by monkey fingers and scraped forearm
