Results 1 to 21 of 21
    Active Member Synthetic's Avatar
    Aug 2015
    Springfield, MO
    Default 2015 RTL Headlights Won't Switch Between Hi-Beam & Low Beam
    Any ideas why I can't change from Hi-Beams to Low-Beams on my headlights?
    It used to make quite a racket when switching but now makes no noise and lights do not change...
    Thanks for any help....
    Very Active Member spyderCodes's Avatar
    Jan 2016
    PA
    You might start by checking fuse 5 in the right hand jcase box. The lower, larger fuses.
    It could be loose.
    Default HEADLIGHTS
    F-3 now has twin filament, but if yours has the SHUTTER I have a doubt both became STUCK at the same time !!!! so it could be the switch has failed ......it's under warranty .....and Pitbull is just down the road .......Mike
    Aug 2015
    Springfield, MO
    I checked fuses 5, 6 and 7 on right side fuse box and all were fine.
    I'd say it has the shutter set up as it sounds like a shutter when operated....at least it used to.
    Jun 2010
    Las Vegas
    Are you stuck on high beams? Then the shutter is stuck open. Usually one side will go wonky and the other side will still operate normally.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jan 2016
    PA
    Quote Originally Posted by Synthetic View Post
    There isn't a 6 or 7
    Take a look on page 153 of your owner's manual
    Aug 2015
    Springfield, MO
    Quote Originally Posted by spyderCodes View Post
    You're right it is fuses 3, 4 & 5 ....I shouldn't go by memory....
    Aug 2015
    Springfield, MO
    SpyderAnn, I can't tell if it is high beam or low beam....the high beam low beam indicators work but nothing else changes...
    Aug 2015
    Springfield, MO
    I did just replace the headlights and fog lights with TricLed LED's.....but I'd think just changing out the bulbs for LED's would not cause this to happen...
    Jan 2016
    PA
    Could you have forgotten a connector or maybe not pushed them together?
    Aug 2015
    Springfield, MO
    I don't think so....I counted them and made sure they were snapped in connection.
    Jan 2016
    PA
    It's easy enough to knock something loose.
    At least I have a long list of stuff that I have.
    I don't remember if the shutter is operated by a separate connector but it might be worth a looksee again.
    Aug 2015
    Springfield, MO
    I assume it would be a bad connection in the headlights and not fog lights which would be easier to check...I'll probably take it back apart tomorrow and make sure everything is well connected...thanks
    I'm going to guess you inadvertently jammed the shutter mechanism with the LED light wires or the power module. For more info about what you have to deal with check out these two threads.
    http://www.spyderlovers.com/forums/s...25#post1109325
    http://www.spyderlovers.com/forums/s...28#post1116028
    Sep 2014
    USA
    You did install the Positive and negative on the lights correctly?? Because they will not work if inverted.
    I found mine had to be reversed even tho the connector was installed correctly
    Default HEADLITES
    ....WITH POSTERS on #14 & #15......( I didn't know you switched to LED's )......both are common issues with that swap........Mike
    Aug 2015
    Springfield, MO
    I put black to black wires....the Spyder's terminals were reversed.....I did put the LED drivers and wires inside of the door so I may have blocked the shutter mechanism....did not know there was a shutter mechanism and did not know I had to make sure the drivers and wires did not block the shutters...I am guessing you are correct and that is the problem...will check out the links and start taking Spyder back apart again..
    Thanks for everyones help...
    Sep 2014
    USA
    also if you have not done this already remove the led cover on the bulb..Mine had the blue cover. I think the newer kits they ship will be without the light covers..
    Yep the lights will not work if the polarity is reversed..Ask me how I know..
    Mar 2013
    Shutter blockage would be my guess as that was my problem when I tried to stuff everything under the cover. I ended up doing it the same way as Lamont, but I notched the covers and not the housing thinking that if I had to go back to stock (Like trading in) I could just swap them.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Active Member SpyderSteveFL's Avatar
    Dec 2015
    South Florida
    Yea, I also bet it's shutter blockage. Since the harness comes up on that side its almost natural to want to stuff it in on that side where there is more room. With enough patience you can get the driver box and connector down the side like the directions show. The connector is the harder part, but you can get it down there past the silver ring. I actually tested mine and watched the shutter before I put the cover back on and it all works and no cuts. Lamonsters LED looks like it has a larger driver box so it may not actually fit in there.
    NEW/CURRENT (Wife's Bike, I ride Goldwing/Africa Twin)
    2023 RT Limited Petrol Blue Metallic
    Working on the upgrades... so far... Show Chrome Isolator Fuse Block, Tackform Adventure Wireless charger phone mount
    OLD/TRADED
    2015 RT Limited Intense Red Pearl
    Farkles: Ultimate Tallboy seat, FOBO, JT Dash Mount, Lamonster Spyder Cuff, Kradellock, TricLED lighting - fenders, A-Arms, saddlebags, run/brake, Custom Dynamics high brake light, brake modulator, Drink2Go passenger, MUTH turn signal mirrors, Bajaron sway bar, Kuryakyn ISO grips, SpyderTV front grilles & rear trunk organizer, homemade trunk light
    Pending: Elka shocks, Yokohama S Drive rear tire, EVO 595 front tires, Centramatic balancers, Neutrino black box
    Aug 2015
    Springfield, MO
    The new LED driver was blocking the shutter....I used a Dremel tool to make exit slot in cover and the HI/LO's work just fine. Thanks for all of the help....
