Results 1 to 8 of 8
Thread: DESS by pass
    Dec 2015
    St Johns, Michigan
    Default DESS by pass
    There is a series of button pushing for overriding the DESS error. I had it happen twice this weekend. A fellow spyder owner did the series of pushing things and it started. He informed me I should always shut off the machine in neutral. (I had been leaving it in 1st) he had a hard time remembering the series but happened to get it. Anyone else know this series?
    Vermont
    Default D.E.S.S.
    There is a D.E.S.S. thread " D.E.S.S. KEY CODE AGAIN!!!!!!!!!!!!!!!!!!!!!!" I started the thread, on 8/13/15 by: Deanna777.
    The thread has a lot of info, and "What to do when you get the D.E.S.S. error.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Vermont
    Quote Originally Posted by itsakathy View Post
    Did you try **** Turn on/off immediately and DO NOT LET THE SYSTEM SHUT DOWN for 4 to 5 cycles. ****
    I did the above when I had the D.E.S.S. module replaced twice( first replaced on July 14,2015 and the second on Aug.28th, 2015)
    What year is your spyder?
    What spyder model do you have?
    How many miles do you have on your spyder when you had the D.E.S.S. error show up?
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Dec 2015
    St Johns, Michigan
    That may have happened I guess. It was shut on off several times.
    Vermont
    Was that it? What year is your spyder?
    What is your spyder model?
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Dec 2015
    St Johns, Michigan
    Deanna
    2014 rtl it has happened off and on since I bought it as a demo last july 2015. Dealer reprogrammed keys. Still happened. Last weekend happened twice. Once I was able to wait a few minutes and then it was fine. Second time it wouldn't reset. Until a fellow spyder owner did a series of button pushes then it started. May have been coincidence but it started.
    Vermont
    Have you seen/or read my Thread "D.E.S.S. KEY CODE AGAIN!!!!!!!!!!!!!!!!!" ( it has 16 pages as of now) their is a lot of info. on that thread.
    If you have any questions please send me a pm. I will try to help you.
    Or if you get the D.E.S.S. error again, please post on that thread, I would like to centralize the D.E.S.S. errors that people are having on that thread. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Dec 2015
    St Johns, Michigan
    I haven't I will read. Thanks!
