Page 4 of 4 FirstFirst 1234
Results 76 to 86 of 86
  1. #76
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by TIMMB View Post
    Here is an aftermarket trunk replacement, it says seat but those are the trunk part numbers posted in the item information.
    https://www.amazon.com/gp/product/B0...S6F7RLJ5&psc=1
    Link doesn't work.
    Try this one, https://www.amazon.com/Replaces-7083...8627471&sr=8-2
    Last edited by Peter Aawen; 03-12-2023 at 08:39 AM. Reason: Fixed quoting display & link ;-)
  2. #77
    Mar 2019
    Ruidoso Downs, New Mexico
    I read a bunch of replies then jumped ahead, hope I didn't miss the answer to MY issue!
    I added a rack to the top of the box on my F3 Limited, easy with the supplied 'dimples'. But now the box lid will not stay open. I carried a stick on my trip to AK last year but would like to figure out a better solution. Unlike the RT boxes (I guess), the F3 doesn't use a strut but the 'springs?' are built into the hinges. Any thoughts?
    2020 F3L; gone but not forgotten are all the good miles!
  3. #78
    Very Active Member al0vely's Avatar
    Apr 2016
    Indiana
    Quote Originally Posted by K80Shooter View Post
    Is this for the 2020+ or 2019 and older?
    If 2020+ how many have installed and if so how is it working? This looks like a non returnable item.
    Love my Spyders
    2016 F3L Steel Black purchased 7/16/2016 Sold 3/11/2023 (22,500 mi)
    2014 RTS Circuit Yellow purchased 3/2/2018
    2020 RTL Petrol Blue purchased 1/27/2023
    Girls on Spyders #3195
    No more 2 wheels
    2020 RTL , Lamonster floor board riser Petrol Blue
  4. #79
    Sep 2017
    Durham,Maine
    I went to McmasterCarr and got a new strut for my seat, you can call them with you info or work it out from the information in the book, in most cases you can get a strut with the right dimensions, and set up, and pick one with a stronger lift! I would take yours off and get all the dimensions, and give them a call, it would be faster and easyer. Good luck
    2012 RTL , Pearl
  5. #80
    Dec 2020
    Hartwell, Ga
    If anyone is interested, Lamonster now carries the strut for the trunk on the 2020+ models.
  6. #81
    Aug 2017
    Austria
    Thumbs up
    Quote Originally Posted by PW2013STL View Post
    For all those who suggested adding a second strut to the trunk be aware that on the 2020 and newer trunks the strut is in a molded cavity on the right side. there is no cavity on the left side so it's not possible to add a second strut. What I did on my 2020 and wife's 2021 was add a helper spring that goes over the strut.
    I picked the spring up at Home Depot. It was in a package of 4 springs. Two of this size and two smaller. I stretched the spring out until it was as long as the strut and then cut off the hooks.
    One end of the strut is pried off by pulling on the spring clip and the other is held on by a 5mm allen screw. The lid is held on by two bolt pins (T20 and 10mm) the left pin is longer then the right.
    The back rest pad is removed by taking out the two T20 screws in the box and then lifting it off.
    Hello, this is a super Idea, may I ask?
    could you please let me know the approx size, length & diameter of the spring?
    so I ca try and get something similar to fix my Back Top Case on my sea to sky!
    thank you in Advance!
    spydersiggi
  7. #82
    Feb 2020
    illinois
    A small rubber door stop between the front of lid to seat back rest works great and for $2.98 a pair. On windy days, the oem strut does not always work. This works all the time. Adapt and improvise- military way of addressing situation.
  8. #83
    Active Member GreyGhost's Avatar
    Sep 2021
    North Texas
    If anyone is interested SlingMods has a heavier trunk strut back in stock ($40) along with install video..
    2021 RTL Chalk White (a paler shade of grey, of which there are 50)
  9. #84
    Jun 2016
    indpls in
    just installed show chrome strut from value acc works very well easy install
  10. #85
    Active Member mhan's Avatar
    Mar 2021
    Prescott AZ
    Just installed the new heavy duty trunk strut from slingmods on my 2021 S2S with trunk rack. Works great!
    2021 RTL S2S, BRP arm rests, smart mount backrest, Pedal Commander, F3 position B handlebars, adj side vents.
    2021 Sea To Sky , Green
  11. #86
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    Quote Originally Posted by fatboy View Post
    Just ordered mine.
    "Love 'em all.... Let GOD sort 'em out!"
    2021 RTL Dark Chalk Metallic with comfort seat
    1978 GL1000 w/'75 engine show bike
    1976 RD400c
