Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 86
  1. #26
    Active Member Baron14y's Avatar
    May 2019
    Palm Bay, Florida
    Found a paint stick. Cut it to length. Wife painted it white. Works great for as often as I go into the rear trunk. Total cost...Maybe $.02 for the paint.
  2. #27
    Danbury Connecticut
    Quote Originally Posted by Mazo EMS2 View Post
    Now that I have the rack on the lid of the trunk, the stock strut is no longer strong enough to hold the lid up. So, I looked on the BRP parts fiche and see they hose ya for $65 for a strut.... Has anyone replaced or added a second strut for a better price? That's just ridiculous to charge that much. I was reading the thread about the gas strut upgrade for the seat only costing about $10, was hoping to upgrade that one too. Anyone have any links or part numbers they'd care to share for the seat and the trunk struts?
    Thanks,
    Rick
    Quote Originally Posted by glorybiz View Post
    I had the same issue after I put my rack on. First tried a replacement strut and that hardly worked any better. Then I got creative, went to Home Depot and bought a spring to assist the strut, it works great. You just have to stretch the spring out 1 and a half times the length of the strut. Remove one end of the strut and slip the spring over it.Screenshot 2022-06-13 071430.jpg
    I have a 2020 RTL with the added luggage rack. I'm following this thread closely.
    Pierre sells a great little device for those of you with the 2010 to 2019 model. Looks to me like a perfect solution.
    I'm hoping they someone comes out with something similar or the 2020+ models. I imagine the F3 rear trunk has a similar issue.
    https://www.canamspyderaccessories.c...-trunk-holder/
    IBA #47122
    2020 RT Limited Asphalt Grey
  3. #28
    Aug 2016
    Cleveland, Ga
    Thanks,
    Rick
    For the seat uspaparts. com part# c16-20650 it is a 40 lb. lift works great.
  4. #29
    Active Member Schreckftw's Avatar
    Oct 2020
    OH
    The strut on my top case of my 21 is bad I had it at the dealer. Dealer is checking if its covered under manufacturers warranty.
    2021 RT Limited , Deep Marsala Red Metallic (Dark)
  5. #30
    I have a template of Pierre's piece ( as shown in the pic above ).... I looked at the Fiche' for the 2020 rear trunk .... it has a similar plastic hinge assembly so I think it could fit but possibly needs a little trimming .... E-mail Pierre and ask WHY His piece won't work for 2020 + ..... Mike
  6. #31
    Feb 2013
    Edinburg, TX
    Quote Originally Posted by missouriboy View Post
    I'm too lazy for all this. My RPM1 extended warranty covers it, and the new strut is on-order at my dealer right now.
    That was Post #19 back in 2018. Now that replacement strut has failed also. I rummaged around in my shed and found a little odd-shaped piece of 1/4in. board that wedges in and holds the lid just fine. I used a Sharpie pen to draw a vertical line where it fits perfectly... total cost: $.00
    The dimension that fits is 1-5/8" long. Just wedge it between the trunk-box and the hex nut at the top of the strut.
    NEW - 2015 RT Limited SE6 Intense Red Pearl - 07/21/15
    Retained the old mirrors with TricLed Signals
    General Altimax RT43 rear tire (at...17,000 miles) Ran for 36,500 miles
    Michelin Defender.......rear tire (at...53,500 miles) Ran for 60,700 miles
    Riken Raptor HR.........rear tire (at 114,200 miles)
    Vredestein Quatrac 5 front tires (at 70,500 miles, first new fronts!)
    Gear Brake Decelerometer Module
    OLD - 2012 RT Limited SE5 Pearl White - 01/31/13 - Traded in at 32,600 miles.
    BajaRon Anti-sway Bar
    Kumho ECSTA AST rear tire (at 14,200 miles)
    TricLed Turn Signals in Mirrors
    2015 Limited , Intense Red Pearl
  7. #32
    Danbury Connecticut
    Can you message the template to me ?
    I can fabricate something out of plastic in one fashion or other. and modify it if needed.
    IBA #47122
  8. #33
    " message the template " .... .... I would if I could .... I've offered this in other posts .... Just send me your name & address and a Stamp .... and I'll send you a template that you can transfer to plastic or wood. Pierre's model is a hair under 1/2 in. wide ( so it will fit inside the plastic hinge .... mine is 3/8ths and works fine ...... PM me for my address ... Mike
  9. #34
    Danbury Connecticut
    Hey, that's a great idea. I don't know how to get access to the strut. Is it easy ?
    IBA #47122
  10. #35
    Danbury Connecticut
    Figured it out. Thanks glorybiz. Great idea. For about $5.00 solved the problem.
    From the front of the trunk with the passenger back rest removed:
    Looking down the hinge well with the trunk open:
    IBA #47122
  11. #36
    Danbury Connecticut
    see attached link
    http://www.spyderlovers.com/forums/s...runk-gas-shock
    Read it all the way through.
    Cruzr joe
    Hey, thanks for the throwback to the Flame War. I know they're uncivil, but sometimes I enjoy a good boxing match also.
    IBA #47122
  12. #37
    Oct 2021
    Wichita, KS
    My 2022 has the added rack and stays open just fine. I'm not sure what it uses for a strut since there is nothing visible. Maybe it will wear out over time. If anyone needs a piece 3D printed just let me know. I can whip you something up really quick if I have the template.
    Peter Pan has struck again!
  13. #38
    Quote Originally Posted by FrogmanDave View Post
    The struts do wear out ..... it depends on how much it's used, and if you have any extra weight on it ...... I love my HINGE bracket.... Mike ................. If interested, I can tell you how to draw it for your own template ..... let me know ..... Mike
  14. #39
    Dec 2020
    Hartwell, Ga
    I sent you a message.
  15. #40
    Very Active Member Bangorbob's Avatar
    Jun 2018
    Pahrump NV
    Is there a part number for the spring from home depot? I have it all apart. It's just a weak shock. I ain't paying what they want for the same PO Garbage.
    Thanks, Bob
    2005 Roadtrek Chevy 210P
    2020 RT Limited-Chalk White SE6
  16. #41
    Mar 2018
    Madison, WI
    Quote Originally Posted by Bangorbob View Post
    Thanks, Bob
    Not Home Depot, but I got this one on amazon:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    2014 RT - SE6 , Black
  17. #42
    Thanks, Bob
    You actually would be better off to put another shock on the other side. If you put too much force on the lid the tab the ball mounts to will bend. I put fender washers on both sides of the tab to stiffen it. See this post for links to good discussions about the trunk struts. https://www.spyderlovers.com/forums/...=1#post1560507
    Here's info on what I did. https://www.spyderlovers.com/forums/...=1#post1406313
  18. #43
    Danbury Connecticut
    Thanks, Bob
    https://www.homedepot.com/p/Everbilt...6084/202045472
    IBA #47122
  19. #44
    Active Member USAF's Avatar
    Aug 2022
    NY
    How are you getting it onto the strut ?
  20. #45
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by Rick28 View Post
    You take one of the ends off and then slide it on. Then reinstall the end.
  21. #46
    Jun 2018
    Pahrump NV
    Okay, I know I'm getting up there in years and sometimes don't understand a lot of things. Is this thread about 2020-2021? OR 2019 an older?
  22. #47
    Danbury Connecticut
    For both designs of the Spyder RT, you remove the rear passenger back rest and gain access from there. The strut mounting is a little bit different for the pre and post 2020 models, but the spring idea will work for either.
    The photos I posted were for my 2020 RTL.
    I used 1 and 1/2 of the 11/16" springs.
    Remove the strut.
    Compress the strut and hold it compressed using a zip tie. Be careful and safe when handling the springs.
    Slip the springs over the strut.
    Re-install the strut and then cut the zip tie to free the spring.
    Reinstall the passenger back rest.
    Happy Motoring.
    This worked for me. I make no representations that this will work for anyone else.
    IBA #47122
  23. #48
    The bulk of the thread is about the 2019 & earlier RT's, but then there are a couple (few ??) of posts on this page that mention 2020+ Spyders.... apart from Frogman Dave's comment re his 2022 & his offer to print up a part given a template, your post #40 is one of the first to even mention the newer RT's, altho ThreeWheels alludes to them around post #35. So most of the info here is not helpful to you, certainly not anything prior to your post!
    FWIW, I believe that so far, there's not much besides ThreeWheels' spring, the later version of the wedge thing, or a paint stick to help with your lid...
  24. #49
    Sep 2015
    Chilliwack, BC. Canada
    Actually, WWW.CanAmSpyderAccessories.com has a great little SS Rod affair that I purchased and it works great.....no more worries wondering if the trunk lid is going to fall on my head. Check it out!
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
  25. #50
    Jun 2018
    Pahrump NV
    Peter, you are correct. I used to have to proof read for a living. I read the original post and scrolled down to where I saw 2021 RT NOT reading further down that he has an earlier model.
    SORRY
