lifting a F3S
What would be the best places to place a jack/stands
to lift a F3S? I need to get mine in the air so I can
change the stabilizer.
Thanks in advance
Dray
You lift in the center and place the jack stands under the A-arms but you need to get it 24" off the ground. That may not be possible with your jack or jack stands.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
If he has the same jack the extensions will get it up high enough but the issue is stabilizing it at that height. Typical jack stands for motorcycle use aren't that tall. It will require a 2 step lift because you can't fit the motorcycle lift with the extensions in place under the Spyder. So you have to lift the Spyder place jack stands under it, drop the lift, add the extensions and lift again. At this point you could place blocks under the jack stands to get the required height but I would try to get all of the preliminary work done with the Spyder at the lower height so that when you raise it you just have to pull the old bar and insert the new one. Then you can lower the Spyder back to a safer height and complete the installation.
2010 RT- 622
Not an option for most
I just replaced the sway bar on my F3 Friday and this time instead of having the front on a jack and trying to carefully balance it without dropping it (this is how I did my ST, Not a safe option but it worked). This time I used straps on each side of my lower A arms and used the front lift arms on my tractor with the bucket removed and slowly lifted the F3 until it was high enough.
2016 Spyder F3 Limited Steel Black Metallic
Lamonster approved LED Headlights
Lamonsters LED Fog lights
BRP Driver & Passenger backrest
BRP Trailer Hitch
Shamrock Black & Polished
Signature light
Elka front shock's
Rolo Laser Alignment
Dual Power outlets
Garmin 590 GPS
Lifting an F3S
Thanks Guys for all the input!! Gives me some idea of how to accomplish this.
Dray
Dray
When I did my sway bar I placed two ramps on the tailgate of my truck and placed the bike half way up.. Use the emergency bank and block the rear tire.
I think it is much safer that trying to balance it on a jack and stands
mark
Bullies are sad pathetic People
& the 24" is actually 24"---22"-23" won't work well
Why so high? I saw a guy online replace the bar by just driving the Spyder up onto car ramps.
Lifting an F3
Good morning all!! Got my F3 lifted and the stabilizer changed. But not without
removing things not mention in the instructions. I have a bike lift that is 48" wide
and modified it my placing a 2"x10" cut to 65" long and bolted to the end of the
lift. Had to use my ramps to run the scoot upon the table. Strapped it in front and
applied the brake after lifting about 28". I will test it all out when it quits raining.
Thanks again for all the suggestions.
Dray
