Has anyone improved the stock RT muffler without replacing it?
I have a 2015 RT Ltd. Has anyone tried to improve the stock muffler without replacing it? By this I mean opening it up from the end cap and removing/improving baffles, reduced overall weight, etc. I've not opened mine up yet, so I don't know what's inside. I'm fine with how quiet it is, and I'm fine with beefing up the sound a bit as well. I don't want super loud. What I'd like to do more than anything is reduce the overall weight of it. I like the looks of the stock setup and don't really want to spend a bunch of dollars on a new slip-on. Any thoughts out there?
Rob
Not sure...
Have not seen any other than adding a down turn. I have seen many doing the cat delete which dumps a ton of wieght and add a sweet tone. Pit Bull and Lamonster garage have the delete pipe if you go that way...if someone has jumped down the throat of the oem pipe they will chime in...
2012 RS sm5
RT MUFFLER - ALTERATIONS
Try contacting ( via PM ) a member " SPYD3R ", I recall He did MODIFY quite a few RT Mufflers......there are PIC's of His stuff but I don't know exactly where.......Mike
Thanks, I messaged him.
Rob
Tags for this Thread
