Page 1 of 2 12 LastLast
Results 1 to 25 of 32
    Very Active Member SNOOPY's Avatar
    Aug 2013
    Default 2013 ST Shock choices .... no Fox
    Well after about a year and about 3500 miles with my Fox shocks on the front end one of them developed a leak.
    Fox tells me they don't warranty their shocks but I can send in the shock and they can see "if" they can fix it ...for $150
    So looking for what else is available before spending another $400 on Fox shocks because they wont sell me "one" replacement either.
    Looked at the Elkas and wonder if anyone has or recommends these? http://www.elkasuspension.com/produc...-rs-s-st-2013/
    Bossier LoUiSiAna
    If fox doesnt offer warranty them. bite the bullet & upgrade to elkas. Lots of good reports. JMHO
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Aug 2013
    May be doing a Fox shock destruction video soon...
    YOu might want to talk with the Elka folks first. I'm not sure if they suggest periodic rebuilding of their shocks or not.
    But Fox does.
    Greenville Tx
    I had Elka's installed at spyderfest. Its like night and day difference. no compairison. I still have my Fox shocks if you are interested but if I were you, I wouldn't bother. Just call Elka, but talk to them first. They build the shock for your individual need. I have stage one shocks but its the spring they pick out for you and how they adjust it before they ship it out.
    2017 F3 Limited
    Greenville Tx
    Everyone talks about The Baja Ron Sway bar but going to the Elka shocks is the best performance mod you can do to your Spyder.
    2017 F3 Limited
    Aug 2013
    But Fox does.
    Not sure what you're saying.
    Fox rebuilds them, but only being a year to year and a half old w/ low miles...no reason for a leak.
    Aug 2013
    Quote Originally Posted by AY4B View Post
    Thanks.
    Only thing I see on the Elka site for an ST is a Stage 2 or a Stage 5. I understand they build them close to your weight and style of riding. I use to have shocks built for my ATVs the same way.
    Ill have to call to see specifically what they have if different than their website.
    Aug 2013
    I have the Baja bar on already.
    Default Little checking..
    There are the Elkas, the Race Tech's, Progressive and the oem's....I did have the oem's with the BajaRon swaybar & links and the Pit bull relocators and the spyder handled great. I recently found some affordable Fox podiums and things got even better. From what you say I will keep an eye on them though they have been great for 5,000 or so miles....
    ​2012 RS sm5
    Very Active Member IGETAROUND's Avatar
    Oct 2011
    Kalamazoo, Mi
    Default 2013 SR shocks
    read the fine print carefully on the elkas; they recommend rebuild at what seems to be a ridiculously low mileage/time. Perhaps understandable if your running on a track; doesn't seem practical for the road use. Elkas were all the rage here 2 years ago; then people started reporting problems and failures and don't seem to hear nearly as much about them now.
    All the great movements in the world began with a cup of coffee!
    2018 F3-T
    My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
    2018 F3-T , Pearl White
    Greenville Tx
    Quote Originally Posted by SNOOPY View Post
    So do I, That was one of the first mods I got when I got my ST limited. It was a great improvement, but I am heavy and was bottoming out a lot. No more of that and the handling is also much better.
    2017 F3 Limited
    Aug 2013
    Yeah I really liked them, too bad they don't back them up with a failure so soon.
    Aug 2013
    Quote Originally Posted by IGETAROUND View Post
    Thanks, I'll look into it. I don't put many miles on mine between just running around town and having other toys.
    Invalid Emails
    Mar 2012
    Gore,Quebec,Canada
    I have had my Elkas since 2012 although I have low mileage 20000k, ( do to health,Renos and work getting in the way of riding)have not had any leakage yet, and man what a difference in ride compared to the stock shocks.
    2012 RT , stock Lava Bronze
    Aug 2013
    I can't find anything on the Elka site about service intervals or recommendations.
    Oct 2015
    Lynden, WA
    Default Elka's
    I had Elkas installed at Spyderfest on my 2013 STS
    Made a significant difference in the ride and handling.
    For me the springs are the best feature. They are preloaded for my weight.
    Damping improved the highway high speed handling.
    Overall my confidence in riding improved with the Elkas.
    Yes I have a Baja Ron sway bar and laser alignment too.
    Cheers, David C
    Invalid Emails
    Jun 2014
    mt., home,ar.
    Default elka shocks
    call john at elka shocks 1 800 557 0552 ext257
    Aug 2007
    Greeneville, TN
    Whatever you end up putting on the front of your Spyder, I agree with Fox that you don't want a brand new shock on one side and a 1.5 year old shock on the other. It is important that the shocks have equal function. No way to get that with 1 new and 1 used.
    Still, it's not the years, it's the mileage (where have I head that before?).
    Oh! Now I remember!
    Sep 2015
    Saratoga, ca
    Default 💋💋 my Elkas!
    I had Elka shocks put on, as well as the sway bar, and I put on wider tires at the same time. Not sure where the difference is, but way smoother and I have a lot more stability when riding a little more aggressively, but not too much( don't tell my hubbie")
    Oct 2011
    Kalamazoo, Mi
    Default 2013 ST shocks
    I knew I'd seen a post on the forum about this; take a look @ this:
    http://www.spyderlovers.com/forums/s...8-ELKA-problem
    And your correct; they tell you NOTHING about required maintenance on their web site!!!
    2018 F3-T
    Aug 2013
    Quote Originally Posted by Haze View Post
    Cheers, David C
    Thanks
    Aug 2013
    Quote Originally Posted by j-mak View Post
    Cool, thank you.
    Aug 2013
    I didnt think about that
    Sep 2013
    Houston
    John came back and told us the rebuild interval is for race shocks, not the street use shocks on the Spyders. They also stood behind the shock that failed.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
