Results 1 to 16 of 16
    Registered Users debbie spyder rider's Avatar
    Jan 2015
    Kansas
    Default Issue with Shifting into Reverse
    I just noticed this morning as I was trying to back out of the garage--I am unable to get the Spyder (2014 RT/S) to shift into reverse. Shifting to all other gears is normal, and the Spyder rides normally. But it is just not going into reverse. Can anyone think of anything I should try, or simple things I should check for. I am not much of a mechanic--quite the opposite!!
    Thanks!!
    Debbie
    Mar 2015
    forrest above Reno, Nv
    Default Warentee??
    Hi Debbie,
    I also have a '14 RT-S. If yours is still under warentee ---- get it to the dealer. It's a straight foward adjustement.
    No reverse on a will cause:::
    Kaos
    2014 RTS , Circuit Yellow
    Jun 2012
    Bowling Green Mo. 63334
    Default Shifting to reverse
    Quote Originally Posted by debbie spyder rider View Post
    Thanks!!
    Debbie
    Make sure you are holding down the reverse button on handle bars, when trying to shift to reverse, just a thought. Hope you get it shifting.
    Bossier LoUiSiAna
    Make sure you are applying brake & wouldnt hurt to check your oil level
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    hI Debbie,
    My 2014 RT can also be a bit of a "bear", to get into reverse at times. I have found that I just need to be a bit more methodical, and make sure that I've got the button firmly held down; before thinking about trying to engage reverse.
    Slow and steady, will get you there!
    Jan 2015
    Kansas
    Default Thanks all!
    Thanks for the replies. I'll try a couple more times. The RT is under warranty, so if I can't get it to shift into reverse, I'll be taking it in.
    Thanks again!!
    Debbie
    Jan 2015
    Kansas
    Default For those interested--This worked!!
    I called and talked with someone in the service department here locally, and described the problem I was having. The service man recommended I hold down the reverse button (like usual) and then "flick" the gear switch to reverse. Sounded a bit strange to me, but alright, I'll try..... And.... It worked. Now the RT is shifting into all gears normally. I thought it was bizarre. Flick to reverse. Don't know what I was doing before, but flicking seems to be the key.
    Active Member metman's Avatar
    Mar 2013
    Glasgow, KY
    Default Flicking
    This sounds a lot like problems some have had when shifting into neutral.
    Just a quick "flick" is all that's necessary. The same seems to hold true for shifting into any gear, just "flick it".
    Mike in KY
    Thanks for letting us know that you've found a solution!
    Invalid Emails
    May 2016
    Columbia,tn
    Thanks!!
    Debbie
    Some times on my 2011 I have to push the reverse button twice to get it in reverse. It doesn't do it all the time. Just every now and then. Especially when first getting started in the morning.
    Very Active Member SteveLaoyster's Avatar
    Nov 2015
    Myerstown, Pennsylvania
    Default Two or one.....
    Hi Guys. I'm working on getting my first from imotorsports & I've been reading parts of the owners manual. Just wondering if it's easier to shift into reverse with one hand or using both hands?
    Of course this would be on a SE5/SE6.
    AKA Jud Smales, Four Year Spyder Ryder!
    "Quando Omni Flunkus, Moritati"
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Driver & Passenger Gel Pads in Seat
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Break Stripe Kit from Wrap My Spyder
    2016 RT-S , stock not yet Pearl White
    Feb 2012
    Spring City,Utah
    I always use 2 Hands. I have also found it is easier if I push the button 1st then lightly hit the lever( on the reverse side).
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    I've always just laid my left thumb on the button, and then wrapped around the front of the grip, to hit the paddle with my index finger...
    But hey...
    Besides: I normally use both hands, to operate the cruise control...
    Have always used two hands for the reverse shift. My fingers are not long enough. After 8 years, I don't think I am going to change.
    Very Active Member hypurone's Avatar
    Jun 2016
    NorCal - Northbay
    Weird, when I do this it causes a very loud and unpleasant "shift" to reverse. When I press and hold the shift lever (with button held obviously) it goes into reverse smooth and quiet.....
    Chuck
    Nov 2015
    Default Thx!!!!
    Thanks for the information!!! Ryde on!
    BajaRon Sway Bar
    Foam Grips
    Shorty antenna
