Results 1 to 14 of 14
Thread: Brake Rotor
    Active Member danotech's Avatar
    KC
    Default Brake Rotor
    I am in need of a front brake rotor for a 2014 RT. Please let me know if you have a spare or a source for a new one.
    Dan
    Sent from my SM-G930T using Tapatalk
    Nov 2015
    Piqua Ohio
    Default Bajaron
    Sponsor on here quick service and good prices
    Default BRAKE ROTOR
    Quote Originally Posted by goat232 View Post
    You could have issues if you replace one ROTOR , I would recommend TWO from BAJARON, they will help you stop better and they well last longer and I'm quite sure TWO of His are LESS than one OEM from BRP.........Mike
    Jul 2010
    Las Vegas, NV
    Default Concur
    What Mike said. BajaRon has great stuff.
    Joe Meyer
    Sep 2014
    USA
    Default Try this..
    BajaRon first...cheapcycleparts.com (oem rotors) ebay may have them then there is brp
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Quote Originally Posted by danotech View Post
    Dan
    Just curious as to why you need to replace the rotor.
    KC
    I believe it is warped. I'm getting vibration in that wheel during braking. Suggestions?
    KC
    If I did have to replace one what is your cost?
    Mar 2013
    Marion, Arkansas
    Just go to home page and click on his website and you will find what your looking for and a lot more goodies.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    I would check the rotor for warpage before replacing it. Worn A-Arm bushings can give you the same effect as a warped rotor.
    I only carry the EBC replacement rotors. It would be very bad to put just one on the front as the EBC rotors stop quite a bit better than the OEM rotors. You do not want uneven stopping power on the front wheels. So you'd need to purchase 2. You might look into a used OEM rotor. Though you may run the risk of getting someone else's problem.
    A new OEM rotor will cost you about $250.00. The EBC rotors are $104.00 each delivered.
    Mar 2015
    forrest above Reno, Nv
    Smile Material Transfer
    Another possibility is material transfer from the brake pads. If the warp test with a dial indicator shows only a few thousands deflection M/T is a possibility, A good sanding and cleaning will do the trick.
    Kaos
    2014 RTS , Circuit Yellow
    KC
    One more question, torque value of rotor bolts?
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    Brake caliper 50 ft lb the rotor is not bolted on it falls out when you take off the brake caliper
