Frunk weatherstrip
Wondering if anybody has good ideas for replacing the frunk weatherstrip. Spyderpops seems a little expensive, but not hugely so. JUst wondering if there are other options. It's a 2010 RS-S.
Spyderpops replacement is a little better quality than the OEM, i replaced mine and am very happy.
Cruzr Joe
SpyderLovers Sponsor
Pops
It works. The OEM poor quality. We put one on the 622. Dry as a bone! Joe
Joe Meyer
It's effectively the same a car trunk seal so if you have a specialist rubber supplier there you could possibly find an alternative to the EOM stuff, however I'm not sure if it would be cheaper than Spyderpops. Over here it's NZ$18.99 a metre so would work out more expensive. Personally I think all Spyderpops stuff is very reasonably priced.
Spyderpops it is then. Thanks all!
Most rubber stripping and seals is out sourced, it's probably available by the foot, even on ebay.
In the twisties I was playing the tart...
It was good advice. Easy swap and great fit. Thanks!
