Results 1 to 6 of 6
Thread: Air in damper
    Mar 2016
    Cedarville, NJ
    Default Air in damper
    I'm confused, my spyder is bouncing like a bucking Bronco. I have an auto air adjustor + a schrader valve. Do I need to fill the air damper using the valve or does the compressor fill it from zero. It seems less bouncy when I started at zero, but I don't feel or see it raise , like I do with the valve.
    Have you tried checking the pressure in the air bag via a tire pressure gauge on the valve?? Put too much air in there & it will make the ride bouncy!! Another thing to check is the chart/table in the manual that gives you an 'idea' of what pressure to use vs the weight you have on the bike as well as detailing the upper & lower pressure limits you should keep it between - might be worth checking that out!
    Mar 2016
    Cedarville, NJ
    Default AIR PRESSURE IN REAR
    Bouncy......really,....if I have 80 lbs in the rear bag it rides like a BRICK........the less ability the spring has for movement the harsher the ride......jmho......Mike
    May 2013
    Stanton, ca
    As a point of reference, my RT when the ride switch is set to the middle setting the pressure in the air bag is 48 PSI.
    Bob
    Mar 2016
    Cedarville, NJ
    Quote Originally Posted by finless View Post
    Bob
    I manually put 45psi in it + it bounces especially with wife on back.( 130 lbs. ) maybe I need more air. Didn't check it when I let auto compressor do it ,because I can't see or feel bike raise. I'll try next time. I'm thinking maybe the shock is done for.
