Trailer wiring
I have a 2015 RTL with a factory trailer hitch and trailer wiring. As you know the BRP wiring plug is a square box female plug. An after market brand X trailer from a certain SL sponsor will have a 4 or 5 wire flat male plug. Where can you get an adapter that will solve all the connection issues and make everything work as it should.
Mike Campbell
Amarillo, Texas
2015 RTL "intense red pearl"
Can't help with a 5 pin connector but on the Flat 4 pin connector just cut the end off the trailer plug and attach a square 4 plug (same color Wires and features).
Cruzr Joe
Where to buy
Cruzr Joe
Where do you buy such this adapter. I have never seen one except on BRP stuff. What would you call it.
Mike Campbell
Amarillo, Texas
2018 F3 LIMITED
It is called a Hopkins Square 4 trailer plug, follow the attached link.
http://www.googleadservices.com/page...DSPM1612914414
Cruzr Joe
Thanks Cruiser Joe & Billiebovine
I knew someone would know!
Mike Campbell
Amarillo, Texas
