If you're sure it's coming from the rear it could be the nylon shock bushing or the swing arm bushings or bearings. If you are handy you could raise the rear wheel and unbolt the shock and test both the shock and swing arm.
SpyderLovers Sponsor
Squeaks
Check the rear shock bushings. Jack up bike, remove lower shock bolt. Move swingarm up and down. If no squeak, clean and replace bolt. Move swingarm up and down. Have good ears!
Joe Meyer
